Release ASUS GT-AX6000 Firmware version 3.0.0.6.102_34793 (2024/08/28)
bennor
Part of the Furniture
As mentioned by @Erwin in the Release ASUS GT-AX6000 Firmware version 3.0.0.6.102_34791 thread, there is new firmware out for the GT-AX6000.
Version 3.0.0.6.102_34793 61.74 MB 2024/08/28
Fixed injection vulnerability.
What would "Fixed injection vulnerability" be exactly?
How bad it is depends on whether it requires being logged in or not and whether it’s exploitable from the WAN side. Since they pushed out this firmware solely to fix this one issue and less than a month after releasing the first firmware in over a year, I’m assuming it’s on the bad side.
It may be related to https://securityvulnerability.io/vulnerability/CVE-2024-42757
There was POC code released for that which would explain the rush.
I had a few odd issues after installing, rolled back after a day, reapplied today, no more issue
Working well here, no problems. Pretty simple home network configuration, though.
Mine is failing to install. I've tried using the update in the router's GUI, as well as downloading the file from Asus to my PC and uploading it to the router via wired PC.
Getting "Firmware upgrade unsuccessful. This may result from incorrect image or error transmission. Please check the version of firmware and try again."
I'm "stuck" on 3.0.0.6.102_34791-g92f56f9_385-g2830d
You can try a factory reset to fix the issue.
New firmware out for the GT-AX6000.
Version: 3.0.0.6.102_34797_404
Do you have a link to it? I'm not seeing it yet. Thx.
. . . just curious, but is fusion/vpn still the ui abomination it's always been? merlin-ware's version is one of the major reasons, i went rogue.
Merlin is not rogue! I only use Asus firmware for AiMesh nodes.
. . . and your POINT??!
are you ok? by that, i mean literate? i NEVER wrote that "merlin" was rogue! perhaps you need help with your ENGLISH. i described my own act (rogue), k. now i certainly have some thoughts about you, but this is a family board.
This is the release notes for the new firmware.
Firmware version 3.0.0.6_102_34797-g974b24d_404-ge7bfb
- Release Note -
Bug Fixes and Enhancements:
  1. Optimized memory management mechanisms, improving system efficiency and stability.
  2. Strengthened input validation and data processing workflows, further protecting your information security.
  3. Improved web rendering engine, enhancing browsing experience and security.
  4. Enhanced security of system command processing to guard against potential malicious operations.
  5. Perfected JavaScript-related security mechanisms, offering a more secure web interaction environment.
