Asus GT-AX6000 stuck in boot loop after firmware upgrade
BLT89
I recently bought an AX6000 from ebay.
Everything worked fine, but the firmware was outdated so first thing I tried to do was upgrade the firmware since it was on 3.0.0.6.102_21514
No matter what I did I could not get it to take the update. I tried the auto update from the UI, when that didnt work I tried to manually upload the firmware from the UI. I tried various versions, and I even tried the latest Merlin FW as well. It would just keep saying the update was unsuccessful.
I tried multiple times to do a hard factory reset with the WPS button. The factory reset would work but it would still fail to update firmware afterwards.
I also triple checked the model on the bottom of the router matched the model for the firmware files I am downloading.
Then I stumbled upon a thread in here talking about validating that the storage was writable and not read-only. (https://www.snbforums.com/threads/gt-ax6000-write-protected-aka-borked.90156)
However, I was able to successfully validate that the Volume was in a state of OK and was writable (`touch /jffs/test.txt` worked)
I then found a tutorial for putting the router in rescue mode and flashing the firmware manually that way.
I was able to get the router in rescue mode, and was able to ping 192.168.1.1 successfully, however when I tried loading the firmware via the Firmware Restoration Utility, it was not able to connect. Just kept saying "router not in rescue mode", even though it definitely was.
Well, I probably should have taken all these roadblocks as a sign from the universe to just stop trying. But I was determined.
I then switched to a different PC, put the router in rescue mode, pinged 192.168.1.1, then tried again. This time the upload worked!! However, when it was doing the upload I noticed something funny. The progress moved steady until it got to 55%, then the progress bar reset and it started over again, this time going up to 23%. Once it reached that, it said the upload was successful. I thought "huh, that was weird. But it says successful so I guess it worked".
After a minute the RGB light on the router started to pulse slowly, like it was booting up. Then the light turned solid for a few seconds, then the light turned off, then started pulsing again. It just repeats like this indefinitely.
I then tried the same process a bunch more times, using different firmware versions, swapping the ethernet cable, changing the port its plugged into. Everything gives me the same result. Just a boot loop. And it always does the weird progress bar thing.
I called ASUS support and confirmed the device is out of warranty.
I'm really hoping I didn't just flush $200 down the drain. Does anyone have any ideas or anything I can try to get this thing working again?
Thank you in advance!
Given everything you've tried I suspect the router is now unrecoverable (short of opening the case and attaching a serial cable - which is beyond my experience).
The only thing you don't seem to have tried: Put the router in recovery mode again, give your PC a static IP address of 192.168.1.10, and see if you can browse to http://192.168.1.1 . From there you should see the CFE miniWeb Server and be able to reset NVRAM and upload firmware images.
Sorry I forgot to mention I also tried the firmware upload via the rescue mode web interface. It never seems to work, after I click upload it spins for a minute or so then goes to a "Connection Reset" error page.
I dont see any option for doing an NVRAM reset:
I would definitely be open to using serial commands if anyone has experience with that or can point me in the right direction. Having trouble finding anything about it when searching the web.
Did you fix it? Maybe try again. Web interface won't work immediately, at least for me, when I was doing this for TM-1900 years ago. I did not after quite a few tries.
