Release ASUS GT-AXE11000 Firmware version 3.0.0.4.388.23482
cc666
Version 3.0.0.4.388.23482
74.16 MB
2023/06/13
New features:
-Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections. Please refer to https://asus.click/SurfsharkVPN
-iPhone/Android USB auto backup WAN allows you to connect your phone to the router’s USB port and use it as an internet source. Please refer to https://asus.click/AutobackupWAN
-DDNS transfer allows you to transfer your ASUS DDNS hostname from your original router to the new one. Please refer to https://asus.click/ASUSDDNS
Bug fixes and functionality modifications:
-Resolved the issue with login and password changes.
-Resolved the IPSec VPN connection issues.
-Resolved the Instant Guard connection issues.
-Fixed the AiCloud login issue after unplugging and plugging the HDD into the USB port.
-Fixed the issue where Traffic Analyzer sometimes couldn't record data.
-Fixed the time display issue for the preferred upgrade time in the Auto Firmware Upgrade function.
-Fine-tuned the description for port status.
-Enabled DynDNS and No-IP DDNS to use IPv6.
-Fixed AiMesh preferred AP identification in site survey results.
-Updated timezone list for Greenland, Mexico, and Iran.
-Modified the USB application option text in dual WAN.
-Allowed WireGuard Server clients to access the Samba server.
-Fixed memory leak issue.
-Enabled the failback function when using the iOS/Android USB backup WAN.
-The ARP response issue has been resolved, along with the connection issue between the router and the ROG Phone 6 and 7.
-Resolved the issue where the USB path is not displayed on the Media Server page in the AiMesh node
Security updates:
-Enabled and supported ECDSA certificates for Let's Encrypt.
-Enhanced protection for credentials.
-Enhanced protection for OTA firmware updates.
-Fixed DoS vulnerabilities in firewall configuration pages.
-Fixed DoS vulerabilities in httpd.
-Fixed information disclosure vulnerability.
-Fixed CVE-2023-28702 and CVE-2023-28703.
-Fixed null pointer dereference vulnerabilities.
-Fixed the cfg server vulnerability.
-Fixed the vulnerability in the logmessage function.
Please unzip the firmware file, and then verify the checksum.
SHA256: cf42bf2d97efb27ad0ba51b1f0555f68a690b197d25d33127862c81a647e2984
CC
It says "404 - Not Found" on this link provided. Did anyone managed to download it? If yes, could you pls post it?
Interesting...I have Auto Firmware Upgrade turned off on my AXE11000 router, but based on my router logs, it looks like my router automatically upgraded to this new version (3.0.0.4.388.23482) at 5am this morning.
Jun 19 05:00:13 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7769)]do webs_update
Jun 19 05:00:22 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7787)]retrieve firmware information
Jun 19 05:00:22 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7802)]fimrware update check first time
Jun 19 05:00:22 rc_service: watchdog 1315:notify_rc stop_upgrade;start_webs_upgrade
Jun 19 05:00:22 usb: USB is ejected
Jun 19 05:00:22 WEBDAV Server: daemon is stoped
Jun 19 05:00:22 WEBDAV Server: arpping daemon is stoped
Jun 19 05:00:22 iTunes: daemon is stoped
Jun 19 05:00:22 FTP Server: daemon is stopped
Jun 19 05:00:22 Samba Server: smb daemon is stopped
Jun 19 05:00:22 Timemachine: daemon is stoped
Jun 19 05:00:23 iTunes: daemon is stoped
Jun 19 05:00:23 FTP Server: daemon is stopped
Jun 19 05:00:23 Samba Server: smb daemon is stopped
Jun 19 05:00:23 Timemachine: daemon is stoped
Jun 19 05:00:25 miniupnpd[27545]: shutting down MiniUPnPd
Jun 19 05:00:26 ahs: ===Terminate ahs daemon===
Jun 19 05:00:27 disk_monitor: Finish
Jun 19 05:00:27 Mastiff: Got SIGTERM
Jun 19 05:00:28 AUTO_UPGRADE: To download fw/rsa, Start
Jun 19 05:00:28 AUTO_UPGRADE: cfg_trigger=
Jun 19 05:00:28 AUTO_UPGRADE: wget fw Real GT-AXE11000_3004_388_23482-ga3b7e4a_un.zip
Jun 19 05:00:34 AUTO_UPGRADE: exit code: 0
Jun 19 05:00:34 AUTO_UPGRADE: wget fw Real GT-AXE11000_3004_388_23482-ga3b7e4a_rsa2.zip
Jun 19 05:00:34 AUTO_UPGRADE: mv trx OK
Jun 19 05:00:37 AUTO_UPGRADE: fw check OK
Jun 19 05:00:37 AUTO_UPGRADE: To download fw/rsa, End
Jun 19 05:00:37 rc_service: rc 16334:notify_rc stop_logger
May 4 22:05:11 kernel: klogd started: BusyBox v1.24.1 (2023-06-04 01:26:53 CST)
Same here. Update was installed with Auto Firmware Update OFF.
I'm having issues with xt8 aimesh after update on gt-axe11000
It will connect light on front goes white connects for about a minute then disconnects light flashes blue then reconnects like stuck in loop, have factory reset both gt-axe11000 and xt8 and both have latest firmware on them.
This firmware version messed up my aimesh setup big time. I have 3x aimesh nodes, each on latest firmware. My aimesh setup was working perfectly fine with previous GT-AXE11000 firmware version 3.0.0.4.388_22525 - now backhaul connections are unstable and hardly any devices can connect with the aimesh nodes, totally messed up. I reverted to previous firmware version 3.0.0.4.388_22525 and it's stable again. However I see same issues as others are having above, update keeps getting installed with Auto Firmware Update OFF. This is a real nightmare.
I'm a proponent of always going with latest updates etc for security, vulnerabilities, etc. and I would really like to stick with 3004_388_23482 but it's totally unstable. I tried factory reset, all tricks up my sleeve - but same results. Only way to get back to stable state is revert firmware but it's getting super annoying when I revert only to see this update again deployed on my gt-axe11000 without my consent.
Is anyone from ASUS looking at these posts ? Wondering if new firmware requires different settings for me to get back to stable aimesh backhaul connections like with previous firmware version ? Looking at release notes there isn't anything obvious to me ....
If anyone has any tips or having same issues with aimesh after this update please share, especially if you have found a solution.
Thanks !
/Felice
I have contacted asus all they said is upgrade firmware and do a reset. I have auto firmware switched off on router latest firmware not showing up via GUI but showing up on app.
I did the reset after the upgrade. Nothing changed, my aimesh setup was still messed up. I did the reset via GUI, I might try upgrading again though and do hard reset on the GT-AXE11000 unit ...
So you are still using the previous firmware then ?
Yes I am still on previous firmware I haven't had chance to upgrade again and reset everything it is solid connection on pervious firmware
Thanks, I really hope someone from ASUS is looking at this thread and can act upon it ...
Nobody from Asus is monitoring these forums (at least, not officially).
If you want then to be aware of the issues, be sure to give feedback via the router GUI and/or phone/email too.
How?
Did you do that via nvram ? I have it turned off in GUI and it's still been overriding the setting and upgrading ....
