Release ASUS GT-BE98 Firmware version 3.0.0.6.102_39244 (2026/02/04)
fruitcornbread
Version 3.0.0.6.102_39244
68.82 MB
2026/02/04
Improvements:
- Optimized Wi-Fi roaming stability for devices supporting 802.11k but not allowing 11v.
- Improved Wi-Fi roaming compatibility and stability for iOS 26 devices.
- Refined accessibility-related UI and interaction details.
- Enhanced stability for 2.5G LAN/WAN port operations.
- Improved overall remote connection stability.
- Improved system behavior when using System diagnostic on feedback page.
Bug Fixes:
- Fixed incorrect connection status display for certain Wi-Fi devices.
- Fixed AiMesh nodes not displayed correctly in the device list.
- Fixed a disconnection issue that occurred after enabling the MAC Filter.
- Fixed main network connectivity issue when enabling IPv6 for both the main network and GUEST NETWORK PRO.
- Fixed a system issue that caused AiCloud features to appear on unsupported models.
Security Enhancements:
- Enhanced system API validation for stronger protection consistency.
- Strengthened command handling and system resource access controls.
- Improved system logging and security event recording mechanisms.
ZIP SHA-256 : E8A27A4C598A0B20E974764B2A640B266FD4158A73D7F01A4C5F6FE0DA2CEDCA
FW SHA-256 : a6f092ca5db6acdb1df372a4a17631f5eef8e1f2f9b2f047c407a7a4170fc5e1
Download: https://dlcdnets.asus.com/pub/ASUS/wireless/GT-BE98/FW_GT-BE98_300610239244.zip?model=GT-BE98
(You will need to copy the link and paste it in a browser for the link above to work.)
