Asus Lan Domain Name
RouterSwitchHub
Hi Everyone,
Currently, the domain name for the asus router is http://router.asus.com/
Is there anyway to customize this to something else?
I tried entering a domain name in the field below but that doesn't work.
Only information i can find online seems to be about the Wan version.
Appreciate the help.
Yes. Just edit the two fields in your screenshot.
If you set Hostname = "RT-AX92U" and Domain Name = "foo.lan", the FQDN becomes: RT-AX92U.foo.lan
router.asus.com will still work as well as it's hard-coded for all Asus routers.
