Asus Merlin and jffs
keef
Hello. I have Asus RT-AC87U router with Merlin 380.7743 firmware. I cannot find the option to enable jffs. According to some install docs I have (Astrill vpn) is should be under Admijnistration->System.
any help is appreciated.
thanks, Bj
My apologies all - I just found the answer. Starting with Merlin 378.50, this option is enabled by default.
Hopefully, the RT-AC87U will work out.
thanks, Bj
You will want to change that setting I've pointed out to "Yes". You will probably need to reboot after for it to take effect
