Asus Merlin - Deluge - VPN
bulbous_blues
Hi
I just installed entware and deluge on my router and all looks good. My question is I'm also running airvpn on my router, will deluge automatically be behind my VPN? Do I need to put the router behind my VPN?
Thanks!
I don't think so. It may be tricky to put it behind your client because its sitting on your gateway. I think in deluge, you can specify an interface though and perhaps you can apecify the tun interface instead.
Actually, I think you can specify the ip address to bind to in deluge. Then it would only work on your vpn which is what I think you want...
Hi Thanks for your reply, I see the settings you mean. I just can't tell if they are working. Do you know how I would be able to test if deluge is behind the vpn?
