Release ASUS ROG Rapture GT-AXE16000 Firmware version 3.0.0.6.102_36387 (2025/05/21)
visortgw
Part of the Furniture
61.96 MB, 2025/05/21
SHA-256 :2D6507A6EF3FEE843831225DE850A9CE0C2F24DB3F919DF22A12D86F3AD055CC
Improved compatibility with certain IoT devices.
Download
No one what?
Most times people write to complain, not to report no problems.
I did the upgrade on both router and node and everything is working as good as before.
If anyone with a Mesh network can confirm this update doesn’t break 6GHz clients that would be awesome and save me a potential downgrade. Thank you.
I have AX16k as main and GT-BE98 as node, all networks (including 6Ghz) work as they should (updated earlier today, no issues yet).
I have GT-BE98 Pro as primary router (Merlin firmware) with GT-AXE16000 (and others) as AiMesh node using 3006.102_36387. Clients connect to 6 GHz on both primary and AiMesh node without issue.
  • Like
Reactions: opq
All my phones and my laptops are connecting to 6GHz on both router and node.
I do share same SSID across all radios so I'm relying on smart connect. It's working just fine as before and as expected.
  • Like
Reactions: opq
Did anyone else's IOT devices' connection reliability fixed by this FW Update stop working reliably again randomly overnight last night? No FW updates on the router, it's an older IOT device so it doesn't get updates, tried to reboot my router, endless Assoc and Disassoc in the System Log. Wonder if the router took a silent security update of some sort..
Disappointed even the ancient AC66U and AC68U routers got updates in Aug/Sept and this “flagship” not that long ago is still sitting around missing out. Asus should really release new FW with flagships they had released in mind. The AXE16000 still gotten the OpenVPN patch!
I am on this firmware since day one with no problems until yesterday. While trying to add a new node my router lost all settings ... as if I had reset it ... Anybody else experienced anything like this ?
Following the GT-AXE11000 which had a firmware update on 4/28 and the AXE16000 which had the last on 5/21, should be/hopefully about 3 weeks later should get one.
@tgd My AXE16000 is an Access Point with mesh nodes. Luckily no such loss of configuration on the latest firmware...
So BQ16 Pro and even the ET12 just got another round of FW updates, so Oct in addition to Sept. Even the AXE7800 was updated. Really shameful of Asus to deprioritize and abandon this not-so-long-ago flagship router.
@opq Hopefully by the 30th....
Just to get FW that has already been superseded on other models.
To be a little more on the fair side (I am not employed by ASUS but do have a friend working there) the/my GT-AXE11000 is still on ASUSwrt 4.0, and admittedly the GT-AX6000 had ASUSwrt 5.0 (3.0.0.6.102_xxxxx for a long time it has been surpassed) AX6000 _34860 AXE16000 is at _36387.
Merlin is on a more updated GPL if you're experiencing trouble _37957. I'd recommend choosing based on the higher GPL...
