I was at best buy snooping around for an additional ASUS router to use as a node for my main AX88U. I have been impressed with my AX88U with its feature set, but I bought it to try and reduce lag/latency for gaming which it hasn't really done.
I was holding the AX58U in my hand and one of the reps at best buy saw me holding it and asked if I was getting it for gaming. He said he bought an ASUS router (didn't know the model but said it was a model above the AX58U) and that he returned it. He wasn't satisfied with the ping/latency.
He directed me towards the router he bought, which was a Nighthawk AX5400. He pointed out the DumaOS, and features that allow you to select the closest server for the best ping. He said it helped out immensely. I think these features are cool but you have to take everything with a grain of salt. The gaming mode and the gaming VPN features that are available on my AX88U haven't really reduced my ping that much.
From Best Buy:
AX5400
Powered by DumaOS 3.0 Enjoy fast online gaming and smooth streaming with the router operating system built especially for gamers. Geofencing Customize, and filter which game servers you play on for an elevated gaming experience. Ping heat map Ping your favorite game servers to display your connection quality to each server on a world map.
So I bought the AX58U anyway and before I open it I wanted everyone's opinion who cares to voice it. Is there anything I can do on my current setup to reduce ping or is there any particular feature I could be missing that is the same or better than the Nighthawk ping map/Geofencing? I know it's unlikely, but is there any chance if we don't have these features that they could be included in a future build?
For reference, I live close to Tampa and I'm on Frontier fiber connection with 1GB up/down. So I think the connection is decent but ping is not as fast as I'd like.
Thanks Merlin Gang!
From Best Buy:
AX5400
Thanks Merlin Gang!
