Asus RT-AC3100 parts repair/replacement
nos
Have two broken antenna parts on this unit:
1 - SMA connector for antenna #3 broke off; piece ended up embedded in antenna housing
2 - For antenna #2 the part just before the SMA connector that's soldered to mainboard (labeled CON 38; thru-hole connection) was off solder-pad, it's pins sheared.
Where can I find replacement parts? TIA
No new replacement parts. Search eBay, local listings, electronics recyclers around.
Router is a freebie I want to restore; found some parts on amazon that may be workable.
