Asus RT-AC3200 and Netgear Ready
Turbogutten
My old router just died, and I bought a Asus RT-AC3200 router and updated it to latest firmware.
I hooked up my Netgear ReadyNas Duo v2 to the new routers lan port and powered it on.
The Netgear ReadyNas Duo is set up to automatically recieve ip adress through DHCP from the router, but it does not show up as a detected unit in the RT-AC3200 admin page, and I am not able to detect it on network or by RaidAr program?
I thought this router provided easy "plug and play" features, or Is it just not possible to connect a ReadyNas Duo to this router ?
Are there any settings in the Asus router I will have to do ?
I have no problem accessing the ReadyNas Duo when connecting directly to a computer, restarting it, and then use the default login ip 192.168.168.168/admin set by ReadyNas when not recieving automatically ip by DHCP
I'm a bit stuck here and hope someone can help ?
