ASUS RT-AC5300 Merlin won't block internet access
zillah
Dear folk
I have got a router ASUS RT-AC5300 with Merlin firmware 384.17
When I try to access AiProtection - Time Scheduling to block internet on some mobiles on certain times of days it won't work.
And those mobile still ca access the internet although they are supposed to be blocked
I would assume we don't to restart the router
Thx
Good advice for up to ~250Mbps ISP with this router. Bottleneck with faster ISPs.
Mine is 100 Mbps
For learning purpose what if it is more than 250 Mbps what would be the other option to avoid bottleneck ?
In home routers some functions limit others. You cant use all the options and keep Gigabit throughput. Not on this hardware.
Noted thanks for sharing
Hi, disable NAT Aceleration in LAN -> Switch Control
Worked in iphone x but not Samsung Galasy S10e,,,,,I have to reboot the router to work !!!
