ASUS RT-AC5300 seperate ssid for VPN
ace_spades
Hi purchased this Router 4 months ago, can be setup so that it can broadcast one ssid which uses a vpn connection and another ssid which doesn't use the vpn connection?
What you are asking for is way too specific. You won't find that specific feature in an off-the-shelves product, you'd have to implement it yourself.
You have several options:
1. Write scripts and install them on your router.
2. Install tomato which supports VLANs and Virtual APs and see if it accomplishes what you want.
3. Use two routers with one double NATed behind the first. One router's SSIDs would connect to the ISP directly and the other router's SSIDs would connect to your VPN. Not as elegant as other solutions, but will work right out of the box.
