Asus rt-ac66u and vpn client
tage
Hi.
Is it possible to make the router to route the VPN tunnel (client mode) only to wifi and leave Lan ports to not use the VPN? Or maybe one of the Lan ports ?
I'm open for any tries and try other firmware than stock.
/tage
Hi.
/tage
The lack of replies suggests that you are asking too much of your kit. I have set up a VPN server and client on my AC88U and there are no options of the sort you require. I'm wondering why you need that specification. If you need VPN on just your wifi clients, then why not set up a server for them in your router or, if you are using VPN to hide your butt, subscribe to a VPN service that has apps for your wifi machines, phones etc.
I use expressVPN . It works on all platforms and can be used for routers, PCs, tablets, phones etc . It costs me about £70 a year with unlimited clients.
https://www.expressvpn.com/?refID=U...f3J_Rm_83JweBnTVfQJT3xXz8FMpA1KRoCn5cQAvD_BwE
