Asus RT-AC66U to Asus RT-AC86U (AC 2900) upgrade
joeejo
Since the ac66u is no longer being supported, I have decided to upgrade to the RT-AC86U.
My question is: Is there any way to install the existing backup configuration from the AC66U on the AC86U directly, or am I required to manually configure? I have a lot of ports, dedicated ips, scripts etc so it would take some time to manually configure.
Thank you
No. Config files are not compatible across routers, they are only meant as backups.
