Release ASUS RT-AC68U / RT-AC66U B1 / RT-AC1900(P/U) Firmware version 3.0.0.4.386_52062 (2025/10/27)
Ok have changed my 5ghz channel to 40 from 112. There is a neighbour using 100 but as far as I can tell very little users in the low numbers.
RT-AC66U B1 only doesn't have DFS support.
Strange but the AC68U at a not for profit i managed did not have DFS channels
Available channels are region and law dependent.
My RT-AC68U definitely has DFS, I have seen 5 GHz channel changes in the system log with a description like "radar detection".
The RT-AC1900U as Media Bridge I did have, appeared to have troubles with automatic 5 GHz channel changes, I finally changed the connection to 2.4 GHz at a fixed channel, and after all discarded the Media Bridge completely (the RT-AC1900U is now stored as spare and experimental box).
18 days up-time and still stable. See how long I can push it after disabling scheduled reboot.
34 days uptime for my RT-AC68U.
Just for reference:
Screenshot 2025-12-08 at 13-38-37 ASUS Wireless Router RT-AC68U - Network Map.png
Older RAM data can be found here:
[EDIT]
11 days past: RAM used still 83 MB, the memory leak as seen in the above older posts seems gone, or the increase was related to the Media Bridge I had in service that time.
And here some recent Radar Detection entries in the System Log:
Dec 10 07:41:35 kernel: SKIPPED false Type 7 Radar Detection. min_pw=228 pw_delta=0 pri=5850 fm_min=1030 fm_max=0 nconsecq_pulses=6. Time from last detection = 3090196, = 51503min 16sec. Detected pulse index: 0
Dec 10 07:41:35 kernel: Type 0 Radar Detection. Detected pulse index=0 fm_min=1030 fm_max=0 nconsecq_pulses=6. Time from last detection = 0, = 0min 0sec
Maybe RAM usage is slowly increasing, see post #26 above for reference:
And January 20:
Ram usage
What's in a number:
RAM Usage is slowly increasing, see posts #26 and #32 above.
All the rest, the Router just does what it is supposed to do without strange messages in the System Log and no Wi-Fi outages.
The screen shots above show routers in basic configuration with no Trend Micro involvement. This is why the memory utilization is 30-40%. It can work like this forever and the uptime you guys show is not unusual. I had one RT-AC68U variant with >400 days uptime. ASUS killed it with bad ASD update some time ago and it was replaced with something else. Not sure why this thread has to be bumped from time to time. 🤔
