Asus RT-AC66U WAN speed limited.
RCNunya
Cox ultimate service, SB6183 modem, Asus RT-AC66U router running Merlin 380.64
Can't seem to get above 150 Mbps.
The router was running tomato firmware, and I read that there is a limitation of that firmware with WAN speed, but that the original Asus or Merlin should work fine.
I reflashed router to Asus firmware and like an idiot forgot to test speed then, but re flashed to Merlin right away. Still being limited to around 140-150 Mbps.
These are wired tests. If I hook a PC directly to the modem, I get over 300 just fine.
I have not made any changes to the Merlin except adding the SSIDs.
Anything else I can try to achieve my full speeds?
Thanks.
