ASUS RT-AC68U and dlna problems
sosooka
Hello everyone.
I have problems with my ac68u and its attached 1TB usb disk (formatted in NTFS): when I go watch on my TV the content of the disk, I see only empty folders (with the disk attached on my pc and serviio it's all ok).
Any solution?
Thanks in advance and sorry for my english.
Which specific USB HDD?
Which firmware are you running on your RT-AC68U?
Have you changed any of the default router settings?
If the folders do show but they all come up as empty then it's possible they are in a format not supported either by your TV or by minidlna.
If using ext2/ext3, make sure the file permissions are set so the files are readable by the router (set them to 777 if in doubt, then restart the Media Server).
with serviio my tv is ok with dlna and this disk..
