Asusnet/Merlin,
Will this build also fix port forwarding for upnp? I noticed it is not forwarding port 3074 at all for the xbox since upg to build 306.
Edit...
I was able to get the port forwarding tab to say it is forwarding to port 3074 on the xbox after about a dozen xbox connection tests...
However... Connection status tab shows the upnp 3074 connections as all unreplied. So upnp is buggy... But port forwarding is not working properly for upnp.
my xbox ports are f'd after the update as well. went straight modem last night because it was pissing me off so much i gave up. unreliable once i got it working too. every time i booted the box it would sometimes forward perfectly and sometimes would suck. hoping the new FW release coming soon fixes it.
