ASUS RT-AC68U Firmware version 3.0.0.4.384.21140
Despite the very limited release note information, the update went flawless.
Let's see if my stable RT-AC68U gets even more stable ;)
Now I wonder if this update includes phase 2 of the AiMesh project....
Should I update or not, that is the big question ... :(
On this firmware if I set the wireless control channel to anything but channel 6 it makes the change but then defaults back to channel 6 after a few minutes.
Anyone else had this problem?
After so long silence from Asus development regarding the beta release I decided to drop that and install the latest regular firmware.
This went smoothly. Coming days will tell me if it was a good decision or not ....:)
My first suggestion is to revert to Factory Defaults, manual configure the router again (do not load a configuration backup) and see how it behaves.
good idea as I can set every channel and it will be used as long as I will change it to another.
new changelog
- [DDNS] Modified the procedure of DDNS service register under dual wan load balance mode
- [WAN] Modified detect logic of internet connection
- [AiMesh] Fixed AiMesh onboarding unsuccessfully once smart connect is enabled
- [AiMesh] Modified AiMesh nodes notification procedure
- [GUI] Fixed AiProtection GUI bugs.
- [GUI] Updated OpenVPN server FAQ URL.
