www.asus.com
I don't work off firmware binaries, I work off source code.@RMerlin you should add the binaries from this release to your custom FW since the last Merlin FW still suffers from this issue
I meant the binary blobs from the source when availableI don't work off firmware binaries, I work off source code.
not only DoT is broken in this FWDoT still broken for Tapo Bulbs and Switches via Alexa. Noticed new DNS settings with descriptions which is good. Back to Merlin which DoT and IoT works.
www.snbforums.com
A work around for your bulbs is to manually assign an IP address to the bulbs (or problem client) and enter a DNS Server (Optional) setting. This will bypass the router DNS.DoT still broken for Tapo Bulbs and Switches via Alexa. Noticed new DNS settings with descriptions which is good. Back to Merlin which DoT and IoT works.
I didn't try it long enough to see if the Wireless backhaul was stable gone to merlin's latest which I am now testing.not only DoT is broken in this FW
Release - ASUS RT-AC86U Firmware version 3.0.0.4.386.48260
Version 3.0.0.4.386.48260 2022/03/25 62.81 MBytes ASUS RT-AC86U Firmware version 3.0.0.4.386.48260 1. Fixed OpenSSL CVE-2022-0778 2. Added more security measures to block malware. 3. Fixed Stored XSS vulnerability. Thanks to Milan Kyselica of IstroSec. 4. Fixed CVE-2022-23970, CVE-2022-23971...www.snbforums.com
Wireless backhaul was stable up to this version. I went back to previous fw, and again work stable.I didn't try it long enough to see if the Wireless backhaul was stable gone to merlin's latest which I am now testing.
Hi, Not sure it is relevant to your case. In an AiMesh setup, there is an option to TURN-OFF LED. The following is a screenshot of the AiMesh setting of my daughter's home with similar Asus Routers as yours. Hope it helps:After upgrading to this firmware on my RT-AC68U, the front panel LEDs are all off, though the router is working fine. I rebooted and watched the LEDs while it came up and they were on and cycling normally, up until the point the web interface came on-line (end of reboot cycle), at which point the LEDs turned back off. Is anyone else seeing this? Thanks.
Mar 30 04:31:19 WATCHDOG: [FAUPGRADE][auto_firmware_check7669)]do webs_update
Mar 30 04:31:22 WATCHDOG: [FAUPGRADE][auto_firmware_check7687)]retrieve firmware information
Mar 30 04:31:22 WATCHDOG: [FAUPGRADE][auto_firmware_check7702)]fimrware update check first time
Mar 30 04:31:22 WATCHDOG: [FAUPGRADE][auto_firmware_check7733)]no need to upgrade firmware
Mar 30 04:31:52 WATCHDOG: [FAUPGRADE][auto_firmware_check7669)]do webs_update
Mar 30 04:31:52 WATCHDOG: [FAUPGRADE][auto_firmware_check7687)]retrieve firmware information
Mar 30 04:31:52 WATCHDOG: [FAUPGRADE][auto_firmware_check7707)]fimrware update check once
Mar 30 04:32:22 WATCHDOG: [FAUPGRADE][auto_firmware_check7669)]do webs_update
Mar 30 04:32:22 WATCHDOG: [FAUPGRADE][auto_firmware_check7687)]retrieve firmware information
Mar 30 04:32:22 WATCHDOG: [FAUPGRADE][auto_firmware_check7707)]fimrware update check once
Mar 30 04:32:52 WATCHDOG: [FAUPGRADE][auto_firmware_check7669)]do webs_update
Mar 30 04:32:52 WATCHDOG: [FAUPGRADE][auto_firmware_check7687)]retrieve firmware information
Mar 30 04:32:52 WATCHDOG: [FAUPGRADE][auto_firmware_check7702)]fimrware update check first time
Mar 30 04:32:52 WATCHDOG: [FAUPGRADE][auto_firmware_check7733)]no need to upgrade firmware
After a Firmware Upgrade from the latest working Merlin Firmware i upgraded to 3.0.0.4.386_48262 and get 980 Mbps but after a factory reset all Problems are back and i only get 485 Mbps. Any ideas whats now wrong?I'm happy to report that this FW fixes the LAN speed cut by half when using the AC68U as a AiMesh node as described in this thread.
@RMerlin you should add the binaries from this release to your custom FW since the last Merlin FW still suffers from this issue![]()
We use essential cookies to make this site work, and optional cookies to enhance your experience.
