Asus rt-ac68u ftp secure
Justhahaha
Does the rt-ac68u have sftp or ftps?
For me usb 3.0 port makes no sense if the ftp is not secured.
Does anyone know the answer to this?
It doesn't have either of them.
Do you know amy router which would have that?
Probably none do out of the box, as it is a fairly advanced feature. You will have to go down the custom firmware route for this.
Do you know any custom firmware that has that feature?
No idea. See what DD-WRT has on their wiki.
Otherwise, you might be able to manually implement it using Optware. This could be done using stock or Asuswrt-Merlin (DD-WRT's Optware support is broken).
Due to the high negative reviews of asus, i went ahead and bought netgear nighthawk r7000. So will i be able to use the above mentioned firmware with the hack for ftps?
