Asus RT-AC68U - Merlin Build - 378.53_0 - Static IP does not show more than 6 assigned static ip.
Feejus
Hi All,
First of all I want to say that I am new here so apologies if this a repeat question.
I am currently running Asus RT-AC68U with Merlin build 378.53. I think i have found a Graphical bug in the software.
Reproduce: Under LAN --> DHCP Server TAB you can add static IP to specific MAC address. The list states that there is a maximum of 128 MAC address / ip addresses allowed. However if you exceed more then 6 of them static address, I.E you add the 7th. It does get added however it is not visible in the GUI. If you try to add it again it does say it has already been added.
This creates a huge security risk, as admin you don't / can't see what mac address are on the fixed ip address.
May i please ask if there is someone else out there with the same issue. Or maybe I have missed something very obvious.
Thank you
Feejus
Works for me, as I have near a dozen DHCP reservations (due to all my development routers). Make sure you're not adding any illegal character in the Name field. Stick to letters and numbers.
My RT-AC68U is on 53_0 and I reserved 18 static IP's; all of which are visible and assigned properly as devices connect.
Thanx for your input, I am wondering if I had some sort of corrupted config, as i started to see all sort of issues. I have now reset the router and it seems to me that it is working much better. With that said I have some odd behavior on the drop down list. It is way to late to provide them now but i try to do it in the next few days.
