Asus rt-ac68u One port as switch
Vybramo
Hello
Its possible to set router to have one port as switch ? and rest of ports as router? I have one device which need to have IP adress from my ISP and i dont want to use gbit switch.
Have you looked at WAN - DMZ? This may help with service you want to use, but it won't make your device get WAN IP address, but why do you need that device to have IP address from ISP? just curious
you cant. DMZ doesnt do that either. DMZ is a 1-1 NAT which doesnt give the device a public IP, but at the same time exposes the device to the internet. So if you need to port forward many ports you use DMZ.
many routers have the typical 2 port config where 1 port is WAN and the other is connected to a 4 port switch. The 4 ports are switched and it is not in the firmware to configure the switching config of the ports either. Only mikrotik lets you do that. On mikrotik you can bridge WAN and another port and switch the rest or use routing to route between an unswitched port and WAN.
