ASUS RT-AC87U & 384.4_2 Network map issues
npapanik
I am having issues on the network map. Any device that is connected to the 5GHz band is shown as wired. If I connect the device to the 2.4GHz band it shows OK.
I don't know if this is unrelated or not, but if I use the same SSID for both 2.4 & 5 GHz bands the devices will always connect to the 2.4GHz band, even though they are 1m from the router.
Known issue - search is your friend.
That 5GHz clients show up as wired clients in the network map.
Most clients will default to using 2.4GHz band, you'll want to use a different SSID if you want them to connect to 5GHz.
