ASUS RT-AC88U - losing internet connection when deactivating VPN Client
Caniwi
Hi All,
A complete newbie and not very technical but loving the new router. I am using ExpressVPN and have set up a number of VPN Clients. Everything works perfectly until I deactivate the current client (usually to switch to another). Anytime I deactivate a client I lose the Internet connection and need to reboot the router. Rebooting works fine but its just a pain. Any ideas? Thanks
Under VPN Client, make sure "Block routed clients if tunnel goes down" is set to NO.
Thanks for the reply it is really appreciated. However, I don't seem to have that as an option though. the only options under VPN Client is to add profiles, activate, deactivate, delete, and edit which is to edit the description, username or password of the VPN Client.
I think robahearts means under each client setup that you have created. Go into each client and make sure "Block routed clients if tunnel goes down" is set to NO. I had trouble with this too, until I worked it out. I would try to switch from one client to another and because I had each one set to "YES" then I couldn't get any access to the internet. YMMV depending on the interface you are using. I have ASUSWRT Merlin firmware installed on a RT-AC68U
It appears to me from the screenshot that this router has stock firmware installed and not Merlin. In that case the option to “block clients if tunnel goes down” is not available.
Thanks Marin. Yep..... that will be it. I'm just using the stock standard firmware it came with. Perhaps I should consider changing to Merlin although everything else is working fine. Cheers!!
P
