ASUS RT-ACRH13 Router as AIMesh node
esfu
Can the ASUS RT-ACRH13 Router be used as a AIMesh node ? I do not see any option in the firmware for AIMesh nor does a search for AIMesh nodes in ASUS router supporting AIMesh show ASUS RT-ACRH13 router even though ASUS RT-ACRH13 is connected as an access point to the network.
The RT-ACRH13 does not list support for AiMesh, so it can not be used as an AiMesh node.
To add an AiMesh node to the root node configuration, reset its firmware first and do not configure it directly (it will no longer be in Access Point Mode then).
OE
OE
Thanks for the update. I appreciate it.
Main Router is RT-AX92U AIMesh in AIMesh/Router mode and not Access Point mode.
RT-ACRH13 is in access point mode connected to one of the wall ethernet socket.
IF the ACRH13 did support AiMesh, you would reset its firmware first before trying to add it as a node... it would then be in its default Router Mode at that time.... not Access Point Mode.
OE
OE
I tried resetting the router, upgrading the firmware to the latest available for the ACRH13 and it still did not help. Search for AIMesh nodes does not find it.
ACRH13 is also not listed in the list of supported routers for AIMesh. Only if and when the firmware for the ACRH13 is updated in future to support AIMesh, will it work as a node I presume.
I doubt the ACRH13 will ever support AiMesh. It's based on a different hardware platform and runs an obsolete branch of the firmware.
