slowmotion
Version 3.0.0.4.388_25210
95.05 MB
2025/05/19
Optimized the app’s remote access capabilities for a smoother and more reliable connection.
Improved compatibility with certain IoT devices.
SHA-256 :C0B3ECB80522A3645ACD6380036C7915493E98CF9EB8A59F087E502583FD379D
www.asus.com
Important update as it fixed the AiMesh roaming problem on my 2-node RT-AX3000 mesh. The previous 25155 got strange glitches that my MacBook Pro insisted to connect to the master node even though it sits beside the slave node. It is now fixed.
95.05 MB
2025/05/19
RT-AX3000|WiFi Routers|ASUS Global
ASUS has a range of wireless routers suitable for every purpose. Whether it's for your home, for business trips, or for any other need or environment, there's an ASUS router for you.
www.asus.com
