Release ASUS TUF-AX3000 Firmware version 3.0.0.4.388_22675 (2025/10/28)
fruitcornbread
Version 3.0.0.4.388_22675
45.65 MB
2025/10/28
- Enhanced system stability.
- Enhanced input validation and refactored legacy string handling routines to ensure robust memory management.
- Mitigated security risks in AiCloud service by enforcing strict credential verification, implementing robust file path validation, and hardening command execution logic to prevent unauthorized access and manipulation of system resources.
- Implemented comprehensive validation and expanded command filtering in the web history API.G1
- Fixed a privilege escalation vector in the IFTTT token exchange mechanism
- Strengthened input validation and directory handling in the VPN configuration upload interface.
- Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.
ZIP SHA-256 : 7E2EB6192D74B8B1D655884F7AD0AFE14B8265B04CDC5C182CE0AA18EB111391
FW SHA-256 : a70df93a1f49bad40e7046664d0161d5133a11f101adb6037013c74d940d1823
Download: https://dlcdnets.asus.com/pub/ASUS/..._TUF_AX3000_300438822675.zip?model=TUF-AX3000
