mhandley92
Hey all,
After doing tons of research, tests, and browsing this forum; I've decided to try and post to get a resolution for my router before I replace it.
Bought in 2021, has worked great but never been updated other than at purchase and switching to asuswrt-merlin 386.3. Tried to do a factory reset and firmware update 3 days ago because it would no longer allow me to login via the web gui. The update installs, completes, and then upon reboot it still shows 386.3. Since attempting, I am constantly losing packets between the firewall and endpoint. I work remote and can't even use teams calls, etc.
Things I've tried:
-I've tried many different firmware versions. Some from 2018, 386.4, 386.8, 388.1, 388.8, etc. All follow the same update with no error, goes to login page, still shows 386.3.
-I've tried different browsers.
-I've tried with the router fully disconnected from anything except the PC via lan port (no wan, no usb, nothing else connected).
-Factory resetting (WPS + Power, also from GUI)
-I attempted to turn on SSH. Seems to apply the setting, but does not listen on port 22, and doesn't accept connections.
-I attempted updating via rescue mode. (Unconnected power cable, held reset with paperclip, reconnected, Power LED slow blinking, Network adaptor IPv4 set IP and subnet mask). Utility just repeats that the router is not in rescue mode.
Is there any break glass method I can use to get this thing updated and back working?
Things I've tried:
