[ASUS RT-AX92U] Android 7.0 TV Box cannot connect WiFi
KennySK
Hi.
My Android 7.0 TV Box cannot connect WiFi.
The logs are shown below:
Jan 7 05:08:55 wlceventd: CAP,E1:30: wlceventd_proc_event(432): eth6: Auth C0:84:7D:3D:8F:EA, status: 0, reason: d11 RC reserved (0)
Jan 7 05:08:55 wlceventd: CAP,E1:30: wlceventd_proc_event(460): eth6: Assoc C0:84:7D:3D:8F:EA, status: 0, reason: d11 RC reserved (0)
Jan 7 05:08:55 wlceventd: CAP,E1:30: wlceventd_proc_event(397): eth6: Deauth_ind C0:84:7D:3D:8F:EA, status: 0, reason: Station requesting (re)association is not authenticated with responding station (9)
Please provide help.
Set the Protected Management Frames in Wireless settings to Capable. Some old devices cannot support that and will fail to connect when PMF set to Required (like my Samsung NoteFE, same as S7)
Set "Airtime Fairness" to "Disabled" for the band you are trying to connect and reboot router. If you are using "Smart Connect", then you have to disable this for both bands. The option is located in Wireless/professional.
Hi.
Hi.
Hi KennySK,
Have you found a solution to this? I am also facing the same situation with my Android TV 7.1 and my August Connect.
Thanks!
