Release ASUS RT-AXE7800 Firmware version 3.0.0.4.388_25192 (2025/08/08)
fruitcornbread
Version 3.0.0.4.388_25192
49.57 MB
2025/08/08
Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security adjustment.
Security Enhancements
- Password Policy Upgrade – Minimum 10 characters with at least 1 letter, 1 digit and 1 special symbol, and no consecutive identical characters; hardens defence against brute-force attacks.
- HTTPS on 8443 – Management interface now served over TLS by default.
- UPnP Disabled – Universal Plug and Play starts in the off state for reduced surface exposure.
- AiCloud Authentication Hardening (CWE-287) – Added layered verification.
- Authentication Logic Refactor – Removed redundant code paths for a lean sign-in flow.
- Memory Safety Guard (CWE-476) – Introduced null-reference protections across critical services.
- Enhanced IPsec Parameter Validation – The existing input checks have been hardened.
- Data Exposure Mitigation (CWE-200) – Reinforced controls on sensitive pathways.
- Detailed Audit Trails – Expanded logging within the authentication module.
System Improvements
- Connection Stability – Core algorithms refined for steadier links.
- Scheduling Accuracy – Timed tasks execute reliably under PPPoE, PPTP and L2TP WAN modes.
- Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list.
ZIP SHA-256 : 248F7DBC548A7B8BBEF0ECE0CB4BDE05621CEBF41389329193C23DB2B97CDC10
FW SHA-256 : ccb24d631bf8f85dec415555596faedfabae958e97a65a0eb54dac8139a9ff6b
Download: https://dlcdnets.asus.com/pub/ASUS/..._RT_AXE7800_300438825192.zip?model=RT-AXE7800
