Release ASUS RT-BE86U Firmware version 3.0.0.6.102_37841 (2025/04/30)
fruitcornbread
Version 3.0.0.6.102_37841
65.84 MB
2025/04/30
Bug Fixes and Enhancements:
1. Improved compatibility with IoT devices on WPA2/WPA3 networks.
2. Enhanced the stability of remote connections.
3. Resolved an issue with the WiFi scheduler.
4. Improved Parental Control scheduling with support for SDN clients.
5. Fixed an issue causing Movistar IPTV to malfunction.
Security fixes:
1. Implemented a security patch to address an OpenVPN issue.
ZIP SHA-256 : D066187E02D60DF136FE255ECDEA5612D0FA35C8CB85A396CB942AA92EF9BC4E
FW SHA-256 : 61d5daa259583287a02d58572aca15a8d59fe8b1874177e3d7ed5c2e39b56577
Download: https://dlcdnets.asus.com/pub/ASUS/wireless/RT-BE86U/FW_RT_BE86U_300610237841.zip?model=RT-BE86U
Going to try a remote 'dirty' upgrade! I know, I like fire! Assuming the app can see the latest release...
EDIT: nope not yet app still says I have the latest firmware...
manually updated seems stable...
Manually updated. Ran ok for 1 day then “ethernet dropped” entries appeared in log. Factory reset and now observing further.
I installed new software but not everything worked well.
I restored factory settings, everything has been working fine for 8 hours.
Installed it few days ago - othervice works, but still can't attach my Nedis smartlife smoke detectors to it. :mad:
The other Nedis components, in- & outdoor smart plugs, + Ecowitt & Shelly products work just fine.
so far I have not noticed anything weird ... it did fix the issue I was having with streaming IPTV over the LAN connection as outlined in the release notes.
