fruitcornbread
Version 3.0.0.6.102_39112
65.18 MB
2025/10/29
- Enhanced system stability.
- Enhanced input validation and refactored legacy string handling routines to ensure robust memory management.
- Mitigated security risks in AiCloud service by enforcing strict credential verification, implementing robust file path validation, and hardening command execution logic to prevent unauthorized access and manipulation of system resources.
- Implemented comprehensive validation and expanded command filtering in the web history API.
- Strengthened input validation and directory handling in the VPN configuration upload interface.
- Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.
ZIP SHA-256 : 62EFCC987A2DF2A041DCAA1A0C628E5E72CB2DDF0B960F2FB39D1644E931198B
FW SHA-256 : f085c2a989d6616cd2a12ae001c349dbf1b0f676daa2c4f5834bc3217a09bfb5
Download: https://dlcdnets.asus.com/pub/ASUS/wireless/RT-BE86U/FW_RT_BE86U_300610239112.zip?model=RT-BE86U
(You will need to copy the link and paste it in a browser for the link above to work.)
www.asus.com
65.18 MB
2025/10/29
RT-BE86U|WiFi Routers|ASUS Global
Dual-band WiFi 7 router with speeds of up to 6800 Mbps, support 4096-QAM, Multi-link operation (MLO), 10G port, subscription-free network security and comprehensive VPN features
www.asus.com
