ASUS RT-BE92U Firmware version 3.0.0.6.102_38979 (2025/10/31)
Can you share the Ethernet Backhaul Mode setting you have? Mine was enabled when it bricked.
I have the same configuration with hardware version 1.0 on both routers. My main router has the 2.4 channel off, while the mesh router has all the 2.4 devices. I think I have Wi-Fi fairness turned on for the 2.4 band. I did a complete factory reset and pushed the button on the back of both routers. Everything’s working fine as far as conductivity, but the one router’s 2.4 band is off.
My setup is:
AiProtection = OFF
MLO = On
Smart Connect = ON
IoT SSID = On
DNS = Control D
QoS = OFF
AiMesh = On, connected to another BE92U
SmartConnectOn: My main network has one password. Guest network_IoT has another password. Could this be causing issues with the 2.4 band dropping? Do you think I made a mistake by implementing two passwords? I really appreciate the information that you've shared and also the video of the setup.
I have a ethernet wired backhaul. Under AI Mesh System Settings, I turned on Ethernet Backhaul Mode.
I use the same password for the main network and the IoT
@2600 Password should not affect dropping. Reading through this thread there are a few others noting 2.4 GHz dropping with this firmware version.
I've had so much poor luck with IoT/guest networks that everything is on my main SSID:
Maybe try turning on 2.4 GHz on the main router.
Create a main 2.4 GHz SSID and password that match the IoT network credentials. May have to turn off/delete the IoT network to try this.
Or revert back to an older firmware as @Texasguy notes resolved his 2.4 GHz dropping.
Experimenting: I believe I’ve resolved the issue with the 2.4 band dropping out. Previously, the 2.4 band would drop out on my main router, and unless I rebooted within 24 hours, it would also drop out on the mesh router too. I didn’t have the MLO feature enabled, and once I enabled MLO, the 2.4 band is now stable and functioning without any issues on the newest firmware. (I don't understand why)
I don't have MLO, but I'll hazard a guess if I may :-) ?
My understanding is that MLO allows devices to connect across multiple bands in a sharing mode, (i.e. 3 bands if the Router has 6Ghz as well) so perhaps devices are not relying solely on 2.4GHz as they may have been, which reduces congestion on the one band? You said you have wired backhaul so it's not that it was using 2.4GHz for backhaul, which is what you were suggesting. Anyway just a wild guess!
Hy,
I have a single router whitout MLO only the wifi 7 is enabled, and i have iot network. This not working for me the 2.4 ghz turning off within two hour. Only the previous firmware or the merlin firmware will solve the problem.
I have my BE92U as an AiMesh node and it has the same/similar issue: 2.4 GHz band goes offline about once a day. Started with the 3.0.0.6.102_38979 update. If I disable the 2.4 radio in the mesh-config it restarts and then I can re-enable it (without a restart).
Edit: Ethernet 10 Gbps backhaul.
Edit 2: MLO is off, 2.4 GHz band uses only 20 MHz.
I'm back to reporting issues with this update, and I'm giving up on... 3.0.0.6.102_38979 update. This morning I woke up and all three radio bands on my primary router were off. My mesh router was the only system broadcasting Wi-Fi. Now, after turning on MLO, all three of my wireless channels goes down on the main router, prior only lost the 2.4 band. Just loaded the previous software version.
I have switched to Merlin and no issue with wi-Fi but active latency control not as good as asuswrt and if I reboot the modem I have to reboot the router too did not have to do that on asuswrt I have to reboot the modem because it unassociated from spectrum service causing packet loss
Anyone else getting a large amount of "kernel: PKT:" spam in their logs? Each one is followed by 16 lines of 16 bytes per line hex dump. There's nothing preceding or following to give any clue as to why. This started on 11/7 for me, almost a week after I updated to the 38979 firmware. There was one instance prior to this firmware on 10/23, and the logs go back to 10/16. Since 11/7, I see several per day to several per hour. Router seems perfectly stable, no dropping of the wifi as others are reporting.
Agree, I loaded the older firmware version, so far so good, it’s been 12 hours
I too just downgraded to 3.0.0.6_102_38962 for the BE92U. I have the BE98 as the main node and 5 other nodes besides the BE92U. The 5 are all different models and they all (including the BE98) work fine with the latest FW - only the BE92U has issues.
As I had updated my routers to the previous firmware and everything's going along fine. And I shut off Auto Firmware Upgrade, although left Security Upgrade turn on. It appears my router updated to the newest firmware version automatically. Although now the routers are working perfectly and not dropping any of the Wi-Fi bands, it's been running perfectly for the last 3 days on Current Version : 3.0.0.6.102_38962-gd4b936e_1425-g5f426_BB0B. This is all a mystery to me.
Prior, I had written ASUS about this problem, and this is the response I got in an email today:
Thank you for contacting ASUS Product Support.
My name is Mariah S. and it's my pleasure to help you with your problem.
We received your report of your 2.4ghz turning off intermittently, specifically after you have updated your firmware. As part of the troubleshooting steps, please confirm if issue will persist once you roll back to the previous firmware. If so, kindly stay on the previous version and submit a new Feedback on the router GUI so our Technical Support Department can investigate the logs and provide the resolution.
We also recommend doing the steps below:
Disable Smart Connect: Go to the "Wireless" section under "Advanced Settings" and turn off "Smart Connect." This will allow you to set up separate networks for 2.4GHz and 5GHz.
[Wireless Router] How to configure the Smart Connect in ASUS Router?
Change the channel: Manually select a different channel, for 2.4GHz network has frequent disconnects may try using a Wi-Fi scanner to find a less crowded channel within the network environment.
[Wireless Router] How to fix wireless Control Channel?
Adjust channel bandwidth: Navigate to the wireless settings and try setting the channel bandwidth to its default value.
[Wireless Router] How to improve wireless speed by setting Channel Bandwidth in Wireless Router?
We also recommend factory resetting your unit based on [Wireless Router] ASUS router Hard Factory Reset - Method 2 as a last resort.
New version available - 3.0.0.6.102_38980.
- Improved network disconnection issue
- Enhanced Wi-Fi stability
I have not tested yet.
