ASUS RT-N66U
TLEH
So here is my problem.
I just flashed TomatoUSB by Shibby on this router, and its working great. Only problem is an odd one.
My 5 Ghz signal only works with no password. When I set the security to WPA2AES or anything really, set a password, and type that password in on my device trying to connect, it either says failed to connect, or invalid password. I know the password is not invalid. If I put no security settings on and connect to the 5Ghz signal, it works flawlessly, doesn't disconnect etc.
Yes I cleared my NVRAM when I set it up.
Transmit power 70 mW
I can not, for the life of me, figure out why this would be a problem. Thanks.
Make sure you stick to alphanumerical for both the SSID and the key. Also delete any existing wireless configuration on your client and reconfigure it (or use a new SSID to ensure you're not reusing old profile settings).
