ASUS RT-NT56U Connection Issues
RRaghu
I have a ASUS RT-NT56U Router. The Firware update that I have currently is : 3.0.0.4.378_4850-g727db45
I have the following Problems with the router. Would appreciate if some one can help me over here....
- The Router disconnects every day at around noon time .....is there a reset time in the router , so that I can change it to a different time.
- The Router disconnects intermittently when visiting some websites (they are random sites ....even like yahoo.com etc) , is there a way to find what setting
is making it to drop the connection?
Thank You
RR
Thank You
RR
If you have not done so already, restore the router to its factory defaults: Administration>
Restore/Save/Upload Setting>Factory Default. Do not use a saved configuration to restore router setup but start from scratch and manually change the bare minimum to return to your desired setup (ie., login, password, wifi security settings, location, etc.).
I use this router as a secondary behind an RT-N66U and it does not reset without a power cycle. You may have a corrupted configuration or you may have updated your firmware without erasing old config data, causing the problem.
If the above fails, revert to the previous (stable) version, 3.0.0.4.376_3879, as the beta version may have introduced some wierdness...it is working fine on my router.
Thank you for the reply .....appreciate it.
Once I reset to factory default, should i have to update the Firmware again to current version?
If resettiing to factory defaults solves the problem, leave it alone and do not update or change the firmware.
Check your modem. I know my cable ISP updates or reboots the modem daily at 2 AM my time.
Sent from my LG-D850 using Tapatalk
