Unhappy ASUS user
Solved!
Hi, I wanted to share my experience with adjusting the settings on my Asus TUF-AX4600 router on the latest firmware 3.0.0.4.388_34011. After adjusting the suggested settings, the router stabilized and seems to finally be working without any problems.
This adjustment was suggested by sevntytwo on the TUF-AX6000 router, as you all know the chipset is the same.
www.snbforums.com
This was my final router config change:
Release - ASUS TUF-AX6000 Firmware version 3.0.0.4.388_33965 (2025/10/23)
I'm on firmware 3.0.0.4.388_31374-g617d05c This firmware is not available for download anymore though. In ASUS world this means there is newer minimum required firmware version for this model router. Going back is not recommended. I have switched off the firmware updates to be sure that it...
www.snbforums.com
- NAT Acceleration (LAN > Switch Control) changed from Auto to Disabled.
- DHCP query frequency (WAN > Internet Connection) changed from Aggressive to Normal.
