fruitcornbread
Version 3.0.0.4.388_24305
95.5 MB
2025/10/27
- Enhanced system stability.
- Enhanced input validation and refactored legacy string handling routines to ensure robust memory management.
- Mitigated security risks in AiCloud service by enforcing strict credential verification, implementing robust file path validation, and hardening command execution logic to prevent unauthorized access and manipulation of system resources.
- Implemented comprehensive validation and expanded command filtering in the web history API.
- Strengthened input validation and directory handling in the VPN configuration upload interface.
- Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.
ZIP SHA-256 : 2DDAB79074E0CBCFEBE31D8DA153307873E88FA28EF68A6CBAF7C918B6E4A79D
FW SHA-256 : 28f4b442beecea23106f45978141b2bef5adc4567ba7d18d34971719da54fe82
Download: https://dlcdnets.asus.com/pub/ASUS/..._TUF_AX5400_300438824305.zip?model=TUF-AX5400
www.asus.com
95.5 MB
2025/10/27
TUF Gaming AX5400|WiFi Routers|ASUS Global
WiFi 6 gaming router for fast, stable connection, eliminate WiFi dead spot for signal coverage. Easy app setup and port forwarding. Mesh WiFi system support.
www.asus.com
