ASUS ZenWiFi AC CT8 need bootloader u-boot
Scenic
Hi
I need a bootloader You can copy it via telnet [program PuTTY] to a pendrive
dd if=/dev/mtd0 of=/tmp/mtd0.bin
or pendrive
dd if=/dev/mtd0 of=/tmp/mnt/your pendrive name/mtd0.bin
example for a router RT-AX92U
CT8 mtd0 is a bootlader
The picture shows the Asus RT-AX92u model, not the CT8
My router was damaged due to bad blocks in nand memory mx30lf1g18ac-ti
Error: CDT is not programmed B - 375020 - Boot error ocuured!. Error code: 302a
