Release ASUS ZenWiFi ET8 Firmware version 3.0.0.4.388_25174 (2025/09/09)
fruitcornbread
Version 3.0.0.4.388_25174
49.24 MB
2025/09/09
This version of firmware is only applicable to ZenWiFi ET8 of HW Ver: 1.0, please check the product label before utilizing. You can check the hardware version from the product SN label or box label.
Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security adjustment.
Security Enhancements
- Password Policy Upgrade – Minimum of 10 characters, including at least one letter, one digit, and one special character; disallows consecutive identical characters; hardens defense against brute-force attacks.
- HTTPS on 8443 – Management interface now served over TLS by default.
- UPnP Disabled – Universal Plug and Play starts in the off state for reduced surface exposure.
- AiCloud Authentication Hardening (CWE-287) – Added layered verification.
- Authentication Logic Refactor – Removed redundant code paths for a lean sign-in flow.
- Memory Safety Guard (CWE-476) – Introduced null-reference protections across critical services.
- Enhanced IPsec Parameter Validation – The existing input checks have been hardened.
- Data Exposure Mitigation (CWE-200) – Reinforced controls on sensitive pathways.
- Detailed Audit Trails – Expanded logging within the authentication module.
System Improvements
- Connection Stability – Core algorithms refined for steadier links.
- Scheduling Accuracy – Timed tasks execute reliably under PPPoE, PPTP and L2TP WAN modes.
- Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list
ZIP SHA-256 : B6F3279ADD3596C62A968EBEC96E560D86AE95042DBC4AD8D353806BCCFD25D7
FW SHA-256 : 22756b0e611bb983b7d37bb5dc7ff3d4db71f53a6f5fa26f1c4972bf6cd2d780
Download: https://dlcdnets.asus.com/pub/ASUS/...ENWIFI_ET8_300438825174.zip?model=ZenWiFi ET8
