Release ASUS ZenWiFi ET8 Firmware version 3.0.0.4.388_25139 (2025/05/08)
fruitcornbread
Version 3.0.0.4.388_25139
49.26 MB
2025/05/08
This version of firmware is only applicable to ZenWiFi ET8 of HW Ver: 1.0, please check the product label before utilizing. You can check the hardware version from the product SN label or box label.
Improved compatibility with certain IoT devices.
ZIP SHA-256 : 8A07652783B801F3286E15090F17D3464424C0A0F940E3F2331CE93BC20D00B3
FW SHA-256 : 0a2db822cb5e05aa4c04ea394d5fd13a25c90842455eaef2d32d6c23d9474344
Download: https://dlcdnets.asus.com/pub/ASUS/...ENWIFI_ET8_300438825139.zip?model=ZenWiFi ET8
Looks like this release breaks 6GHz for AiMesh nodes again. It was fixed in the last release after first being broken in the one before the last.
Actually I think it’s worse than the 6GHz bugs last time, 6GHz doesn’t connect even to the main node. On iOS clients that definitely worked with 6GHz, the “6E mode” option is gone.
Just in case others (or better yet, Asus engineers) could use my data points, after all dirty downgrade the second AiMesh node worked with 6GHz but the main node wouldn’t.
The only thing that worked temporarily for me was creating a new guest 6GHz network, which made my main network work again 2.4/5/6 (a suggestion on Reddit by one user several months ago to get their 6Ghz working again). But turning that 6Ghz guest network off also made my main node stop working with 6GHz again. After which no turning on or off a guest 6Ghz would have any effect and 6Ghz still wouldn’t work on the main node.
So staying on the downgraded FW I factory reset all the nodes and restored from a backup and everything works again.
