fruitcornbread
Version 3.0.0.4.388_24922
49.74 MB
2025/10/29
This version of firmware is only applicable to ZenWiFi ET8 of HW Ver: 2.0, please check the product label before utilizing. You can check the hardware version from the product SN label or box label.
- Enhanced system stability.
- Enhanced input validation and refactored legacy string handling routines to ensure robust memory management.
- Addressed multiple security weaknesses in AiCloud service by enforcing strict credential verification, implementing robust file path validation, and hardening command execution logic to prevent unauthorized access and manipulation of system resources.
- Implemented comprehensive validation and expanded command filtering in the web history API.
- Strengthened input validation and directory handling in the VPN configuration upload interface.
- Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.
ZIP SHA-256 : B76406EAB0F714E52BE9DF1F773E0BFD45233E1D445F6FDEC73CBF95E401354F
FW SHA-256 : 08b565c576b5ba01a1fd5263871ade6b7a88f89565a7dde153e3b0c97e5faa84
Download: https://dlcdnets.asus.com/pub/ASUS/...IFI_ET8_V2_300438824922.zip?model=ZenWiFi ET8
(You will need to copy the link and paste it in a browser for the link above to work.)
www.asus.com
49.74 MB
2025/10/29
ASUS ZenWiFi ET8|Whole Home Mesh WiFi System|ASUS Global
AXE6600 tri-band WiFi 6E (802.11ax) whole-home mesh WiFi system, up to 5500 sq. ft. coverage, new 6 GHz band, Seven 160 MHz channels, 6 GHz and Ethernet backhaul, free VPN security, lifetime free internet security, AiMesh support, ASUS Router app for easy setup and management
www.asus.com
