fruitcornbread
Version 3.0.0.6.102_36637
50.97 MB
2025/10/23
- Enhanced system stability.
- Enhanced input validation and refactored legacy string handling routines to ensure robust memory management.
- Implemented comprehensive validation and expanded command filtering in the web history API.
- Strengthened input validation and directory handling in the VPN configuration upload interface.
- Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.
ZIP SHA-256 : 770586CB2B28902FD087B27B2E9F4E36BAD84E37A7CA3F5D5ED3B86DC0E230B6
FW SHA-256 : 7ffc14b7e0810d5413199a3fe91bd720c6fa41aa942c4477759a2ab0191da086
Download: https://dlcdnets.asus.com/pub/ASUS/..._ET12_300610236637.zip?model=ZenWiFi Pro ET12
www.asus.com
50.97 MB
2025/10/23
ASUS ZenWiFi Pro ET12|Whole Home Mesh WiFi System|ASUS Global
Mesh wifi 6e system for whole home signal coverage, Broadcom, 6GHz, 2.5G ports, network security, parental controls, easy setup and manage. PS5 compatible, supports QoS and app control
www.asus.com
