fruitcornbread
Version 3.0.0.6.102_35254
50.12 MB
2025/08/26
Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security adjustment.
Security Enhancements
- Password Policy Upgrade – Minimum of 10 characters, including at least one letter, one digit, and one special character; disallows consecutive identical characters; hardens defense against brute-force attacks.
- HTTPS on 8443 – Management interface now served over TLS by default.
- UPnP Disabled – Universal Plug and Play starts in the off state for reduced surface exposure.
- Authentication Logic Refactor – Removed redundant code paths for a lean sign-in flow.
- Memory Safety Guard (CWE-476) – Introduced null-reference protections across critical services.
- Enhanced IPsec Parameter Validation – The existing input checks have been hardened.
- Data Exposure Mitigation (CWE-200) – Reinforced controls on sensitive pathways.
- Detailed Audit Trails – Expanded logging within the authentication module.
System Improvements
- Connection Stability – Core algorithms refined for steadier links.
- Scheduling Accuracy – Timed tasks execute reliably under PPPoE, PPTP and L2TP WAN modes.
- Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list
ZIP SHA-256 : 44E74550ABA48DF14A9A6BAFDF4640F57A4EE4D2D1183867245A7087330EFA09
FW SHA-256 : 6fa78b61b0f50e2a3a5afbbd5f57b66b52ffd44079ff53d183acadba1bcb5c4d
Download: https://dlcdnets.asus.com/pub/ASUS/wireless/ZenWIFI_XT12/FW_XT12_300610235254.zip?model=ZenWIFI Pro XT12
www.asus.com
50.12 MB
2025/08/26
System Improvements
ASUS ZenWiFi Pro XT12|Whole Home Mesh WiFi System|ASUS Global
Mesh wifi 6 system for whole home signal coverage, network security, parental controls, easy setup and manage. PS5 compatible, supports QoS and app control
