Asuswrt-Merlin 3.0.0.4.270.26 - Disconnect
DmitryOlenin
Hello.
I have an internet connection by L2TP (Russian provider - BeeLine Moscow).
Today i received a message, when i was trying to open web page: <router page>\error_page.htm?flag=2
Connection was restored after reconnecting at Apr 21 13:08:18 (no auto-reconnect, more than 2 hours passed).
There is some interesting part of logfile:
Apr 21 10:41:52 /usr/sbin/l2tpd[457]: Too many retransmissions on tunnel (9200/29223); closing down
Apr 21 10:41:52 pppd[512]: Terminating on signal 15
Apr 21 10:41:52 pppd[512]: Connect time 7527.3 minutes.
Apr 21 10:41:52 pppd[512]: Sent 1107934125 bytes, received 1970263312 bytes.
Apr 21 10:41:52 pppd[512]: Couldn't set PPP MRU: Transport endpoint is not connected
Apr 21 10:41:52 pppd[512]: Modem hangup
Apr 21 10:41:52 pppd[512]: Connection terminated.
Apr 21 10:41:52 dnsmasq[471]: read /etc/hosts - 3 addresses
Apr 21 10:41:52 dnsmasq[471]: read /etc/hosts.dnsmasq - 1 addresses
Apr 21 10:41:52 dnsmasq-dhcp[471]: read /etc/ethers - 1 addresses
Apr 21 10:41:52 pppd[512]: Exit.
Apr 21 10:41:52 dnsmasq[471]: using nameserver 213.234.192.8#53
Apr 21 10:41:52 dnsmasq[471]: using nameserver 85.21.192.3#53
Apr 21 10:41:52 /usr/sbin/l2tpd[457]: Unknown tunnel 9200 (and another 84 same lines)
Apr 21 10:41:56 WAN Connection: Fail to connect with some issues.
Apr 21 10:41:56 notify_rc : stop_nat_rules
Apr 21 10:41:56 stop_nat_rules: apply the redirect_rules!
Apr 21 10:41:56 /usr/sbin/l2tpd[457]: Unknown tunnel 9200 (and another 826 same lines)
Apr 21 10:42:38 miniupnpd[580]: Failed to get ip address for interface ppp0
Apr 21 10:42:38 /usr/sbin/l2tpd[457]: Unknown tunnel 9200 (and another 16 same lines)
Apr 21 10:42:39 miniupnpd[580]: Failed to get ip address for interface ppp0
Apr 21 10:42:39 /usr/sbin/l2tpd[457]: Unknown tunnel 9200 (and another 34 same lines)
Apr 21 10:42:41 miniupnpd[580]: Failed to get ip address for interface ppp0
Apr 21 10:42:41 /usr/sbin/l2tpd[457]: Unknown tunnel 9200 (and another 62 same lines)
Apr 21 10:42:45 miniupnpd[580]: Failed to get ip address for interface ppp0
Apr 21 10:42:45 /usr/sbin/l2tpd[457]: Unknown tunnel 9200 (and another 112 same lines)
Apr 21 10:42:53 miniupnpd[580]: Failed to get ip address for interface ppp0
Apr 21 10:42:53 /usr/sbin/l2tpd[457]: Unknown tunnel 9200 (and another 125 same lines)
Apr 21 10:43:09 miniupnpd[580]: Failed to get ip address for interface ppp0
I hope for your help. Thank you.
-------5 hours passed-------
Another one disconnect in one day. :(
Another time there is no auto-reconnect.
Logfile:
Apr 21 18:03:36 /usr/sbin/l2tpd[1532]: Too many retransmissions on tunnel (60054/7018); closing down
Apr 21 18:03:36 pppd[1534]: Terminating on signal 15
Apr 21 18:03:36 pppd[1534]: Connect time 294.5 minutes.
Apr 21 18:03:36 pppd[1534]: Sent 3914929881 bytes, received 3694357689 bytes.
Apr 21 18:03:36 pppd[1534]: Couldn't set PPP MRU: Transport endpoint is not connected
Apr 21 18:03:36 pppd[1534]: Modem hangup
Apr 21 18:03:36 pppd[1534]: Connection terminated.
Apr 21 18:03:36 dnsmasq[471]: read /etc/hosts - 3 addresses
Apr 21 18:03:36 dnsmasq[471]: read /etc/hosts.dnsmasq - 1 addresses
Apr 21 18:03:36 dnsmasq-dhcp[471]: read /etc/ethers - 1 addresses
Apr 21 18:03:36 dnsmasq[471]: using nameserver 213.234.192.8#53
Apr 21 18:03:36 dnsmasq[471]: using nameserver 85.21.192.3#53
Apr 21 18:03:36 pppd[1534]: Exit.
Apr 21 18:03:37 miniupnpd[1565]: Failed to get ip address for interface ppp0
Apr 21 18:03:38 miniupnpd[1565]: Failed to get ip address for interface ppp0
Apr 21 18:03:39 WAN Connection: Fail to connect with some issues.
Apr 21 18:03:39 notify_rc : stop_nat_rules
Apr 21 18:03:39 stop_nat_rules: apply the redirect_rules!
Apr 21 18:03:40 miniupnpd[1565]: Failed to get ip address for interface ppp0
Apr 21 18:03:44 miniupnpd[1565]: Failed to get ip address for interface ppp0
Apr 21 18:03:52 miniupnpd[1565]: Failed to get ip address for interface ppp0
Apr 21 18:03:58 pppd[1690]: Plugin pppol2tp.so loaded.
Apr 21 18:03:58 pppd[1690]: pppd 2.4.5 started by admin, uid 0
Apr 21 18:03:58 pppd[1690]: Using interface ppp0
Apr 21 18:03:58 pppd[1690]: Connect: ppp0 <--> l2tp (85.21.0.240)
Apr 21 18:04:21 /usr/sbin/l2tpd[1532]: Too many retransmissions on tunnel (33694/24135); closing down
Apr 21 18:04:21 pppd[1690]: Terminating on signal 15
Apr 21 18:04:21 pppd[1690]: Modem hangup
Apr 21 18:04:21 pppd[1690]: Connection terminated.
Apr 21 18:04:22 pppd[1690]: Exit.
Apr 21 18:04:55 /usr/sbin/l2tpd[1532]: Too many retransmissions on tunnel (25395/0); closing down
Apr 21 18:05:28 /usr/sbin/l2tpd[1532]: Too many retransmissions on tunnel (16146/0); closing down
Apr 21 18:08:04 miniupnpd[1565]: Failed to get ip address for interface ppp0
Beeline's service is... weird. Don't know any other ISP with a similar setup.
I suspect it might be a problem with your modem or your Internet service however:
Hard to tell as I have no experience with those tunneled Internet services. Sorry.
I had been using a Tomato firmware before. There was no problem with "retransmissons".
There was only one problem: 1/2 of WiFi speed in comparison with your firmware.
I looked for answer in internet - no answers, just some ideas about Torrent.
I have set restriction for upload in UTorrent. Let's see.
There are other problems:
1. I have freezes for 10-30 seconds in web-interface. Sometimes it freeze until rebooting.
2. No auto-connect to l2tp after hard-reboot (AC out and in after web-interface freeze).
3. I have MTU 1428 (discovered by ping) on my PC. I can't find MTU setting in firmware (1460 is recommended by Beeline).
ip link list:
1: lo: <LOOPBACK,MULTICAST,UP,10000> mtu 16436 qdisc noqueue
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eth0: <BROADCAST,MULTICAST,UP,10000> mtu 1500 qdisc pfifo_fast qlen 1000
    link/ether bc:ae:c5:c2:f3:03 brd ff:ff:ff:ff:ff:ff
3: eth1: <BROADCAST,MULTICAST,UP,10000> mtu 1500 qdisc pfifo_fast qlen 1000
4: vlan1@eth0: <BROADCAST,MULTICAST,UP,10000> mtu 1500 qdisc noqueue
5: br0: <BROADCAST,MULTICAST,UP,10000> mtu 1500 qdisc noqueue
7: ppp0: <POINTOPOINT,MULTICAST,UP,10000> mtu 1456 qdisc pfifo_fast qlen 3
    link/ppp
I had used command "/sbin/ifconfig ppp0 mtu 1460 up" within telnet to get mtu 1460.
What can i do with freezes and no reconnecting after reboot?
ScottW
Thank you, i know about "c" option.
Maybe that was a bad illustration, but i have freezes like a "ping without c" after confirming some firmware options (not for all, of course).
I didn't see that kind of freezes nor in Tomato nor in RT-N16-1.9.2.7-rtn-rxxx.
Can't do anything...
No internet devices was using. All PC, laptops were in shutdown mode.
12:57:08 - another one disconnect.
However, there was reconnect in 3 minutes.
MTU 1456 at ppp0 was restored after reconnect (how can i save it?).
Logfile:
Apr 22 12:57:08 /usr/sbin/l2tpd[667]: Too many retransmissions on tunnel (5888/29542); closing down
Apr 22 12:57:08 pppd[671]: Terminating on signal 15
Apr 22 12:57:08 pppd[671]: Connect time 635.1 minutes.
Apr 22 12:57:08 pppd[671]: Sent 94971334 bytes, received 1299720721 bytes.
Apr 22 12:57:08 pppd[671]: Overriding mtu 1500 to 1460
Apr 22 12:57:08 pppd[671]: Overriding mru 1500 to mtu value 1460
Apr 22 12:57:08 pppd[671]: Couldn't set PPP MRU: Transport endpoint is not connected
Apr 22 12:57:08 pppd[671]: Modem hangup
Apr 22 12:57:08 pppd[671]: Connection terminated.
Apr 22 12:57:08 dnsmasq[471]: read /etc/hosts - 3 addresses
Apr 22 12:57:08 dnsmasq[471]: read /etc/hosts.dnsmasq - 1 addresses
Apr 22 12:57:08 dnsmasq-dhcp[471]: read /etc/ethers - 1 addresses
Apr 22 12:57:08 dnsmasq[471]: using nameserver 213.234.192.8#53
Apr 22 12:57:08 dnsmasq[471]: using nameserver 85.21.192.3#53
Apr 22 12:57:08 pppd[671]: Exit.
Apr 22 12:57:10 WAN Connection: Fail to connect with some issues.
Apr 22 12:57:10 notify_rc : stop_nat_rules
Apr 22 12:57:10 stop_nat_rules: apply the redirect_rules!
Apr 22 12:57:48 /usr/sbin/l2tpd[667]: tunnel_establish: gethostbyname failed for 'tp.internet.beeline.ru'
Apr 22 12:58:28 /usr/sbin/l2tpd[667]: tunnel_establish: gethostbyname failed for 'tp.internet.beeline.ru'
Apr 22 12:59:08 /usr/sbin/l2tpd[667]: tunnel_establish: gethostbyname failed for 'tp.internet.beeline.ru'
Apr 22 12:59:48 /usr/sbin/l2tpd[667]: tunnel_establish: gethostbyname failed for 'tp.internet.beeline.ru'
Apr 22 13:00:15 pppd[1089]: Plugin pppol2tp.so loaded.
Apr 22 13:00:15 pppd[1089]: pppd 2.4.5 started by admin, uid 0
Apr 22 13:00:15 pppd[1089]: Using interface ppp0
Apr 22 13:00:15 pppd[1089]: Connect: ppp0 <--> l2tp (85.21.0.240)
Apr 22 13:00:15 pppd[1089]: Overriding mtu 1500 to 1460
Apr 22 13:00:15 pppd[1089]: Overriding mru 1500 to mtu value 1460
Apr 22 13:00:18 pppd[1089]: Overriding mru 1500 to mtu value 1460
Apr 22 13:00:18 pppd[1089]: CHAP authentication succeeded: CHAP authentication success, unit 3260
Apr 22 13:00:18 pppd[1089]: local IP address 89.178.35.116
Apr 22 13:00:18 pppd[1089]: remote IP address 89.178.0.1
Apr 22 13:00:18 pppd[1089]: primary DNS address 85.21.192.5
Apr 22 13:00:18 pppd[1089]: secondary DNS address 213.234.192.7
Apr 22 13:00:18 miniupnpd[942]: ioctl(s, SIOCGIFADDR, ...): Cannot assign requested address
Apr 22 13:00:18 miniupnpd[942]: Failed to get IP for interface ppp0
Apr 22 13:00:18 miniupnpd[942]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Apr 22 13:00:18 dnsmasq[471]: read /etc/hosts - 3 addresses
Apr 22 13:00:18 dnsmasq[471]: read /etc/hosts.dnsmasq - 1 addresses
Apr 22 13:00:18 dnsmasq-dhcp[471]: read /etc/ethers - 1 addresses
Apr 22 13:00:18 dnsmasq[471]: using nameserver 213.234.192.7#53
Apr 22 13:00:18 dnsmasq[471]: using nameserver 85.21.192.5#53
Apr 22 13:00:18 notify_rc : start_nat_rules
Apr 22 13:00:18 start_nat_rules: apply the nat_rules!
Apr 22 13:00:18 notify_rc : stop_upnp
Apr 22 13:00:18 notify_rc : start_upnp
Apr 22 13:00:18 miniupnpd[1118]: HTTP listening on port 46697
Apr 22 13:00:18 miniupnpd[1118]: Listening for NAT-PMP traffic on port 5351
Apr 22 13:00:20 WAN Connection: WAN was restored.
I am going to use 3.0.0.4_354.28-Beta1. Maybe it is a clue to my situation.
I made install, restore factory settings, restore my settings, reboot.
MTU is 1460, it is interesting, hope this would be permanent.
I have the same provider. Sometimes, maybe once in two months, I have similar lines in my log. It seems, BeeLine is doing something with their setup in the evening, and in the morning it could be fine again.
Отправлено с моего GT-I9300 через Tapatalk
It's ok, but i have same line every day. Sometimes 2 times during one day.
And, what's so bad, router can't reconnect after this.
What can i do?
Your router isn't recommended. I heard this already many times :(
Have you tried asking on the Beeline support forums? I know there are quite a few users with RT-N66U on their service. They might have suggestions for you to try.
Hello Merlin! Thanks for all your hard work, we really appreciate it!
I have the same issue with the Beeline ISP on my RT-N66U, and haven't found a solution yet.
For most of the time the L2TP connection is stable (my personal record is 16 days), but sometimes after disconnection the router wouldn't reconnect. For example, this morning the connection was lost and the system log looked like this:
Apr 26 08:46:35 /usr/sbin/l2tpd[525]: Too many retransmissions on tunnel (23630/4898); closing down
Apr 26 08:46:35 pppd[12183]: Terminating on signal 15
Apr 26 08:46:35 pppd[12183]: Modem hangup
Apr 26 08:46:35 pppd[12183]: Connect time 1600.2 minutes.
Apr 26 08:46:35 pppd[12183]: Sent 2758717096 bytes, received 2253646376 bytes.
Apr 26 08:46:35 /usr/sbin/l2tpd[525]: Unknown tunnel 23630
Apr 26 08:46:35 miniupnpd[12213]: Failed to get IP for interface ppp0
Apr 26 08:46:35 miniupnpd[12213]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Apr 26 08:46:35 dnsmasq[545]: read /etc/hosts - 3 addresses
Apr 26 08:46:35 dnsmasq[545]: read /etc/hosts.dnsmasq - 1 addresses
Apr 26 08:46:35 dnsmasq-dhcp[545]: read /etc/ethers - 7 addresses
Apr 26 08:46:35 dnsmasq[545]: using nameserver 213.234.192.8#53
Apr 26 08:46:35 dnsmasq[545]: using nameserver 85.21.192.3#53
Apr 26 08:46:35 pppd[12183]: Couldn't set PPP MRU: Transport endpoint is not connected
Apr 26 08:46:35 pppd[12183]: Connection terminated.
Apr 26 08:46:35 /usr/sbin/l2tpd[525]: Unknown tunnel 23630 (repeated 114 times)
Apr 26 08:46:35 pppd[12183]: Exit.
Apr 26 08:46:35 /usr/sbin/l2tpd[525]: Unknown tunnel 23630 (repeated 645 times)
Apr 26 08:46:38 WAN Connection: Fail to connect with some issues.
Apr 26 08:46:38 notify_rc : stop_nat_rules
Apr 26 08:46:38 stop_nat_rules: apply the redirect_rules!
Apr 26 08:46:38 /usr/sbin/l2tpd[525]: Unknown tunnel 23630 (repeated 1277 times)
Apr 26 18:23:36 notify_rc : restart_wan_if 0
Apr 26 18:23:36 dnsmasq[545]: read /etc/hosts - 3 addresses
Apr 26 18:23:36 dnsmasq[545]: read /etc/hosts.dnsmasq - 1 addresses
Apr 26 18:23:36 dnsmasq-dhcp[545]: read /etc/ethers - 7 addresses
Apr 26 18:23:36 dnsmasq[545]: using nameserver 213.234.192.8#53
Apr 26 18:23:36 dnsmasq[545]: using nameserver 85.21.192.3#53
Apr 26 18:23:36 stop_wan(): perform DHCP release
Apr 26 18:23:36 dhcp client: skipping resetting IP address to 0.0.0.0
Apr 26 18:23:36 kernel: br0: port 1(vlan1) entering disabled state
Apr 26 18:23:36 kernel: vlan1: dev_set_promiscuity(master, 1)
Apr 26 18:23:36 kernel: br0: port 1(vlan1) entering listening state
Apr 26 18:23:36 kernel: br0: port 1(vlan1) entering learning state
Apr 26 18:23:36 kernel: br0: topology change detected, propagating
Apr 26 18:23:36 kernel: br0: port 1(vlan1) entering forwarding state
Apr 26 18:23:40 WAN Connection: WAN was exceptionally disconnected.
Apr 26 18:23:47 notify_rc : restart_wan_if 0
Apr 26 18:23:47 stop_wan(): perform DHCP release
Apr 26 18:23:47 dnsmasq[545]: read /etc/hosts - 3 addresses
Apr 26 18:23:47 dnsmasq[545]: read /etc/hosts.dnsmasq - 1 addresses
Apr 26 18:23:47 dnsmasq-dhcp[545]: read /etc/ethers - 7 addresses
Apr 26 18:23:48 dnsmasq[545]: using nameserver 213.234.192.8#53
Apr 26 18:23:48 dnsmasq[545]: using nameserver 85.21.192.3#53
Apr 26 18:23:48 kernel: br0: port 1(vlan1) entering disabled state
Apr 26 18:23:48 kernel: br0: port 1(vlan1) entering listening state
Apr 26 18:23:48 kernel: br0: port 1(vlan1) entering learning state
Apr 26 18:23:48 kernel: br0: topology change detected, propagating
Apr 26 18:23:48 kernel: br0: port 1(vlan1) entering forwarding state
Apr 26 18:23:49 WAN Connection: Fail to connect with some issues.
Apr 26 18:23:50 dhcp client: skipping resetting IP address to 0.0.0.0
Apr 26 18:23:50 notify_rc : start_nat_rules
Apr 26 18:23:50 rc_service: start_nat_rules is waitting restart_wan_if 0...
Apr 26 18:24:05 rc_service: skip the event: start_nat_rules.
Apr 26 18:24:06 dhcp client: bound 10.134.15.140 via 10.134.8.1 during 604800 seconds.
Apr 26 18:24:06 dnsmasq[545]: read /etc/hosts - 3 addresses
Apr 26 18:24:06 dnsmasq[545]: read /etc/hosts.dnsmasq - 1 addresses
Apr 26 18:24:06 dnsmasq-dhcp[545]: read /etc/ethers - 7 addresses
Apr 26 18:24:06 dnsmasq[545]: using nameserver 213.234.192.8#53
Apr 26 18:24:06 dnsmasq[545]: using nameserver 85.21.192.3#53
Apr 26 18:24:06 pppd[18926]: Plugin pppol2tp.so loaded.
Apr 26 18:24:06 pppd[18926]: pppd 2.4.5 started by admin, uid 0
Apr 26 18:24:06 pppd[18926]: Using interface ppp0
Apr 26 18:24:06 pppd[18926]: Connect: ppp0 <--> l2tp (78.107.1.253)
Apr 26 18:24:09 pppd[18926]: CHAP authentication succeeded
Apr 26 18:24:11 pppd[18926]: local  IP address 93.80.xxx.xxx
Apr 26 18:24:11 pppd[18926]: remote IP address 78.107.1.253
Apr 26 18:24:11 pppd[18926]: primary   DNS address 85.21.192.5
Apr 26 18:24:11 pppd[18926]: secondary DNS address 213.234.192.7
Apr 26 18:24:11 dnsmasq[545]: read /etc/hosts - 3 addresses
Apr 26 18:24:11 dnsmasq[545]: read /etc/hosts.dnsmasq - 1 addresses
Apr 26 18:24:11 dnsmasq-dhcp[545]: read /etc/ethers - 7 addresses
Apr 26 18:24:11 dnsmasq[545]: using nameserver 213.234.192.7#53
Apr 26 18:24:11 dnsmasq[545]: using nameserver 85.21.192.5#53
Apr 26 18:24:11 notify_rc : start_nat_rules
Apr 26 18:24:11 start_nat_rules: apply the nat_rules!
Apr 26 18:24:11 notify_rc : stop_upnp
Apr 26 18:24:11 notify_rc : start_upnp
Apr 26 18:24:11 miniupnpd[18956]: HTTP listening on port 50581
Apr 26 18:24:11 miniupnpd[18956]: Listening for NAT-PMP traffic on port 5351
Apr 26 18:24:11 ddns update: connected to dynupdate.no-ip.com (8.23.224.120) on port 80.
Apr 26 18:24:12 ddns update: request successful
Apr 26 18:24:14 WAN Connection: WAN was restored.
Apr 26 18:24:15 ddns: ddns update ok
As you can see, it just wouldn't even try to reconnect and stopped after 1000+ messages about an unknown tunnel. After I came home I had to manually reconnect.
My WAN settings are:
Connection type: L2TP
Additional pppd options: lcp-echo-adaptive maxfail 0
All other settings are set to default values.
If you could, please, look at the source code around the error message about an unknown tunnel, maybe that will spill some light on our problem.
Thank you once more!
As I mentioned, there isn't much I can do, since I have no way of reproducing the weird setup Beeline uses for their service, sorry. You will have to hope that Asus has some devs in Russia who can work on this and fix it in the original firmware.
MerliN_RT-N16_3.0.0.4_354.28-Beta1
I have installed it with original Router Firmware Restoration Utility.
All is ok for now. Uptime is 4 days.
Another question...
Do you know why wifi speed with your firmware is 2x better than speed on tomato or rtn-r5051? This is miracle :)
Another question...
Must be different default settings. Tomato uses the same driver as Asus uses in firmware 3.0.0.4.220. 354.28 Beta does use a much newer driver, however it's still in beta, and it has a few issues that Asus are still working on. Still, I doubt it would explain a major performance difference.
Same settings. Only change that i did at all firmwares - change channel to 13.
I was so happy... But 1 hour ago:
Jan  1 04:00:54 /usr/sbin/l2tpd[520]: Too many retransmissions on tunnel (45002/0); closing down
Jan  1 04:01:04 /usr/sbin/l2tpd[520]: tunnel_establish: gethostbyname failed for 'tp.internet.beeline.ru'
Jan  1 04:01:14 /usr/sbin/l2tpd[520]: tunnel_establish: gethostbyname failed for 'tp.internet.beeline.ru'
I will try RT-N16_3.0.0.4_354.27-BETA1b.
Is it possible that Tomato defaults to 20 MHz, but Asus defaults to 20/40 MHz? That would explain the doubling of wireless performance if you use the default settings.
I was trying 20Mhz/40Mhz. I have good wifi speed with 20Mhz too.
Forgot to say... I have good speed of wifi with RT-N16_3.0.0.4_270.26b too.
Some kind of magic is in your firmwares default settings. It's very interesting.
