Asuswrt-Merlin 378.56_2 and Optware-NG - no 'libtinfo.so.5'-library
Huberer
Hello,
I've just updated my RT-AC68U from the latest John's-fork to the latest Merlin version and I also have installed Optware-NG according to the how-to at hqt.ro (to my external usb-hdd). The first program I've installed was the text editor 'nano'. With John's fork I had no issues running this program (last time was some days ago).
But with the latest Asuswrt-Merlin (378.56_2) I get the error after executing the command (e.g. nano /jffs/scripts/services-start):
/tmp/mnt/optware/optware-ng.arm/bin/nano: can't load library 'libtinfo.so.5'
This is the only message I get and nano doesn't start.
Why do I get this error and how can I solve this?
Thanks in advance
Huberer
Try
ipkg --autoremove remove nano
ipkg install nano
I suspect libtinfo was upgraded, while nano remains not re-linked with new version of libtinfo.
Thanks, I will test it when I'm back home. Unfortunately the external drive (connected to USB 3.0) killed the router so I can't connect from the office and test it now.
Just one question. When I've installed Asuswrt-Merlin, I formatted my drive new, so I had to install optware-ng again and also made a new installation with 'ipkg install nano'. That means, that nano must be linked to the new version of libtinfo.
Where do I find this libtinfo? Should it be under /lib or must it be somewhere installed with optware?
That's depends where old nano is: on local drive of router or Optware-ng hosting. I've asked Optware-ng's author to check the repo.
No any library should be used outside of /opt folder. Every Optware-ng binary should use /opt/lib/* libraries.
Thanks for the info. Now I understand.
The curios thing about this is, that I made a fresh installation of John's fork (v14E1) and formatted the external drive via the router. Afterwards I installed optware-ng with nano and everything worked perfect (I think I did that last time last friday).
Because of problems with the USB3.0-drive/freezing router, I decided to swap to the latest Merlin build to test if it has the same problems (in the meantime I found out that the problem is the USB3.0-port on the router). I made a factory reset and installed the Merlin build (it's not possible to go direct from v14E1 to the latest Merlin build, therefore I installed some older Merlin builds before).
After the last installation I made a factory reset and also formatted the drive new. So it must be the latest nano version I've installed.
Try
ipkg install nano
nano was probably upgraded too - I lost the "-w" flag. So I keep having to try twice whenever I run nano - years of habits of constantly using -w are hard to forget :(
So, after a I could fix the freezed router I changed the external drive and made a new install (with new formating of the drive).
Nano runs perfect now. No error anymore and scripting is possible again.:)
Thanks for your assistance and info. This issue is fixed now.
I am in the same boat. That -w command is a must.
No need for the -w command anymore. The problem is fixed now
I run nano multiple times per day (both at work and at home). Getting rid of 10-15 years of habit is kinda hard.
