Thank you!Congratulations, @rung! Your "knock" script has been added under the Utility section!![]()
@ExtremeFiretop ...I've gone through and updated all the Yaz/AMTM-OSR links as I could. Please let me know if I left anything out!![]()
The new Github link is now:
Both scribe itself as well as uiScribe is handled by OSR now:
www.snbforums.com
vnStat-on-Merlin is also handled by OSR now
www.snbforums.com
FlexQoS is also handled by OSR, I've personally been updating this one recently since it's on end-of-life support.
www.snbforums.com
OMG I had no idea you guys were taking on so much!! Thank you for all the github links as well... totally forgot to go down that rabbithole! LOL. Keep up the great work keeping these scripts going!@Viktor Jaep For sure, sorry about that... I guess I forgot to poke you about updating the Catalog...
Here is all the updates still required below:
GitHub - AMTM-OSR/uiDivStats: A graphical representation of domain blocking performed by Diversion
A graphical representation of domain blocking performed by Diversion - AMTM-OSR/uiDivStatsgithub.com
GitHub - AMTM-OSR/connmon: connmon is an internet connection monitoring tool for AsusWRT Merlin with charts for daily, weekly and monthly summaries.
connmon is an internet connection monitoring tool for AsusWRT Merlin with charts for daily, weekly and monthly summaries. - AMTM-OSR/connmongithub.com
GitHub - AMTM-OSR/YazDHCP: Feature expansion of DHCP assignments using AsusWRT-Merlin's Addons API to read and write DHCP assignments, increasing the limit on the number of reservations.
Feature expansion of DHCP assignments using AsusWRT-Merlin's Addons API to read and write DHCP assignments, increasing the limit on the number of reservations. - AMTM-OSR/YazDHCPgithub.com
New Scribe Thread:
Scribe - Scribe v3.2.11 [2026-Mar-22] - Entware syslog-ng and logrotate installer for Asuswrt-Merlin
Release Notes for Scribe v3.2.2 production version now available [2025-Jul-05] 1) IMPROVED: Set correct permissions to the "/var/lib/logrotate.status" file to avoid "world-readable status" warning message. 2) IMPROVED: Modified code triggered by the 'service-event' calls to avoid excessive...www.snbforums.com
The new Github links are:
GitHub - AMTM-OSR/scribe: Entware syslog-ng and logrotate installer for Asuswrt-Merlin
Entware syslog-ng and logrotate installer for Asuswrt-Merlin - AMTM-OSR/scribegithub.com
GitHub - AMTM-OSR/uiScribe: uiScribe updates the System Log page to show log files created by Scribe (syslog-ng). Requires Scribe https://github.com/cynicastic/scribe
uiScribe updates the System Log page to show log files created by Scribe (syslog-ng). Requires Scribe https://github.com/cynicastic/scribe - AMTM-OSR/uiScribegithub.com
GitHub - AMTM-OSR/ntpMerlin: ntpMerlin implements an NTP time server for AsusWRT Merlin with charts for daily, weekly and monthly summaries of performance. A choice between ntpd and chrony is available.
ntpMerlin implements an NTP time server for AsusWRT Merlin with charts for daily, weekly and monthly summaries of performance. A choice between ntpd and chrony is available. - AMTM-OSR/ntpMerlingithub.com
GitHub - AMTM-OSR/spdMerlin: spdMerlin is an internet speedtest and monitoring tool for AsusWRT Merlin with charts for daily, weekly and monthly summaries. It tracks download/upload bandwidth as well as latency, jitter and packet loss.
spdMerlin is an internet speedtest and monitoring tool for AsusWRT Merlin with charts for daily, weekly and monthly summaries. It tracks download/upload bandwidth as well as latency, jitter and pac...github.com
New vnStat Thread here:
vnStat - vnStat-on-Merlin v2.0.12 [2026-Mar-22] - Data Usage and Data Limit Monitoring using vnStat
Release Notes for vnStat-on-Merlin v2.0.8 production version now available [2025-Jul-05] 1) IMPROVED: Modified all SQLite3 calls to capture and log errors in the system log. 2) IMPROVED: Modified SQLite3 configuration parameters to improve the processing of database records. 3) IMPROVED...www.snbforums.com
GitHub - AMTM-OSR/vnstat-on-merlin: vnstat-on-merlin
vnstat-on-merlin. Contribute to AMTM-OSR/vnstat-on-merlin development by creating an account on GitHub.github.com
New Thread link:
FlexQoS - FlexQoS 1.5.3 - Flexible QoS Enhancement Script for Adaptive QoS
Release Notes for FlexQoS 1.4.7 production release now available [2025-June-15] The fork from @dave14305 's repository is now hosted on the AMTM-OSR GitHub repo: https://github.com/AMTM-OSR/FlexQoS 1) Re-enable develop branch for script development. 2) Allow script to remain in failed update...www.snbforums.com
GitHub - AMTM-OSR/FlexQoS: FlexQoS - Flexible QoS Enhancement Script for Adaptive QoS on ASUSWRT-Merlin
FlexQoS - Flexible QoS Enhancement Script for Adaptive QoS on ASUSWRT-Merlin - AMTM-OSR/FlexQoSgithub.com
GitHub - AMTM-OSR/YazFi: Feature expansion of guest WiFi networks on AsusWRT-Merlin, including SSID -> VPN, separate subnets per guest network, pinhole access to LAN resources (e.g. DNS) and more!
Feature expansion of guest WiFi networks on AsusWRT-Merlin, including SSID -> VPN, separate subnets per guest network, pinhole access to LAN resources (e.g. DNS) and more! - AMTM-OSR/YazFigithub.com
GitHub - AMTM-OSR/scMerlin: scMerlin allows you to easily control the most common services/scripts on your router. scMerlin also augments your router's WebUI with a Sitemap and dynamic submenus for the main left menu of Asuswrt-Merlin.
scMerlin allows you to easily control the most common services/scripts on your router. scMerlin also augments your router's WebUI with a Sitemap and dynamic submenus for the main left menu of A...github.com
OMG I had no idea you guys were taking on so much!! Thank you for all the github links as well... totally forgot to go down that rabbithole! LOL. Keep up the great work keeping these scripts going!![]()
Perfect! Now everything is cleaned up and ready to go for the NEW YEAR! LOLIt's actually mostly @Martinski believe it or not.
I mostly did the setup of the Organization. And only step in when he requests my assistance on something or he's away of some reason.
Happy to help where I can.
I think there was only 3 add-ons you missed. FlexQoS, Scribe, and vnstat, and the rest was just updating the GitHub links in case someone wants to contribute they should do it at the new repos![]()
Perfect! Now everything is cleaned up and ready to go for the NEW YEAR! LOL![]()
Thanks the the second pair of eyes on that. I had about 3 windows open copying from one to another.Awesome! I went back and reviewed the changes and it all looks good except you missed the Github link for spdMerlin:
Thanks the the second pair of eyes on that. I had about 3 windows open copying from one to another.![]()
Thanks Viktor, but actually my idea was simpler and more static than that. Simply to link to the AMTM-OSR GitHub.Yes... I would definitely like to link to the new AMTM-OSR threads.
I like giving that extra level of customer service and providing direct links to the threads for those who are a little skiddish going to GitHub if they don't understand how to use it. But I totally agree that would make my life a lot easier.Thanks Viktor, but actually my idea was simpler and more static than that. Simply to link to the AMTM-OSR GitHub.
The reason I suggested this (with the link supplied in the original post) is because the addon devs all normally link to the forum thread anyway. So the circle is complete and means for these specific AMTM-OSR addons, you only have to amend the list post once.
I think we're ready for a mockumentary. You in?@Viktor Jaep pretty soon you will have a full cast for the motion picture!
How does one get a prefix added for their addon and with addon name in a blue box?
Yea I usually just throw @thiggins @thiggins @thiggins in there a couple of times, then I say "hey look at me, look at me." and that usually does it. @thiggins is like the muhammad ali of these threads, we may think we float like a butterfly, but he will show us that sting like a bee.Contact the mods to request one. @thiggins would likely be the person your looking for.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
