Asuswrt-Merlin the question
Port Forwarding List Max Limit
  • unlimited
    Votes: 0 0.0%
  • limited 32max
    Votes: 7 100.0%
  • Total voters
    7
GoodieHill
Hi
I have a question
Asuswrt-Merlin has limited Port Forwarding List (Max Limit : 32) , or unlimited ?
Thanks for the reply
Limited, as the webui specifies.
it is possible to change this option?
or set to 50 ?
thx
I have no plan to increase it any further. If you rally need 50 different forwards, then you need to rethink your network, or start using ranges instead of one forward per port. I can't think of any realistic scenario that would require that many port forwards.
