Auto Reconnect VPN
sephiclo
Would it be at all possible to have my Ax86u that I use as a vpn client (merlin flashed) to reconnect the vpn after a short internet outage? My modem/router combo from my ISP resets at least once a day. In my openvpn settings I only see to reconnect at boot, instead of what I used to see on my older Asus "start with Wan".
Set the retry attempts to 0. My client reconnects whether the router goes down, the modem goes down, the server goes down.
Thank you very much, it's exactly what I was looking for. It solves my problem, and gives me options I didn't even know I needed! O.O
If I could bother you one last time though. The autostart part of the script. I don't know how to do it :( I did cd in the terminal and I got to the folder where "post-mount" file is located.
For the love of all IT stuff, I do not know how to open/edit/add a line to that file.
Could you help please?
Thank you, but did that step. I get aut_failed in the logs, and it stops trying after that.
I added some guidance on what to add under this post here... https://www.snbforums.com/threads/v...-surfshark-perfectprivacy-2.79762/post-776164
When you're in an SSH prompt, under the /jffs/scripts folder, use the command:
nano post-mount
Edit the line of code... then hit:
CTRL+O to save... then CTRL+X to exit
Thank you very much for your help everyone, this script is perfect!
I found another way to add that line for the autostart whilst inside the /jffs/scripts folder.
echo "(sleep 30 && /jffs/scripts/vpnmon-r2.sh
-screen) &" | tee -a post-mount
Rebooted the router, killed the modem, restarted it, and everything is back as it should be with the VPN even though I had the AUT_Failed that kept the vpn from reconnecting earlier.
Consider the matter closed, me very impressed.
The internet freaking ROCKS!
Keep on rockin'. ;)
Ctrl+s is a shorter shortcut on the keyboard and it saves directly what you have edited. Instead of extra option to choose what file to save to. Just saying : D
